smo Posted December 8, 2007 Share Posted December 8, 2007 I wish to wire my winches so that not only do they work from the remote lead, but also from a switch inside, how do i go about wiring this in?? Quote Link to comment Share on other sites More sharing options...
white90 Posted December 8, 2007 Share Posted December 8, 2007 easy as a plug in your house 3 core mains flex required mom-off-mom switches required then double up on the connections on the solenoid Quote Link to comment Share on other sites More sharing options...
Orange Posted December 8, 2007 Share Posted December 8, 2007 Take the cover off of the remote plug (on the winch) and wire a switch in parallel using a bit of 3-core flex.... It's not high current or voltage, so shoult be ok with some reasonably small stuff. I used some with rubberised sleeving (if that's the right words) so it's easy to run around all the tight corners into the das of the RR. At leats, I think that's what I did. A grown-up will come along in a minute, I'm sure!! Quote Link to comment Share on other sites More sharing options...
white90 Posted December 8, 2007 Share Posted December 8, 2007 I cut the cable off of Vals VAX she is yet to find that Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted December 8, 2007 Share Posted December 8, 2007 Wiring diagram courtesy of Steve90 Quote Link to comment Share on other sites More sharing options...
smo Posted December 8, 2007 Author Share Posted December 8, 2007 Thanks chaps, i have the mom-off-mom switches (carling ones) and shall get some 3 core mains cable for ease of wiring Quote Link to comment Share on other sites More sharing options...
SteveG Posted December 8, 2007 Share Posted December 8, 2007 Thanks chaps, i have the mom-off-mom switches (carling ones) and shall get some 3 core mains cable for ease of wiring If you want the lights to work on the Carling switches, get some 4 core cable and take the earth back to the switch from the solenoid too. Cheers Steve Quote Link to comment Share on other sites More sharing options...
smo Posted December 8, 2007 Author Share Posted December 8, 2007 While im here, anyone got a diagram for wiring 2 batts in parallel, which one should i take the earth from, which one should i feed the alternator + to?? Quote Link to comment Share on other sites More sharing options...
white90 Posted December 8, 2007 Share Posted December 8, 2007 alt goes to the starter motor rather than the battery http://forums.lr4x4.com/index.php?showtopi...battery+cut+off Quote Link to comment Share on other sites More sharing options...
smo Posted December 8, 2007 Author Share Posted December 8, 2007 Hmm, a few weeks back i had it all clear in my head, now im doing it im confused!!! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted December 8, 2007 Share Posted December 8, 2007 While im here, anyone got a diagram for wiring 2 batts in parallel, which one should i take the earth from, which one should i feed the alternator + to?? It doesn't matter, as they're in parellel - if you're wiring them permanently in parallel. The two +ve are connected together, the two -ve are connected together, alternator/starter to the +ve, chassis/block to the -ve If you're using a split charge solenoid for winching, connect everything to the main battery +ve with only the solonoid between the battery positives. If you're using a split charge solenoid for engine-off current draw, starter/alternator to main battery, solenoid between the two, your loads on battery2 +ve. Quote Link to comment Share on other sites More sharing options...
