bushwhacker Posted December 13, 2007 Share Posted December 13, 2007 Has any one found a way to run the exhaust other than under the cross member, were it can take a bit of a bashing. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 13, 2007 Share Posted December 13, 2007 What vehicle, what engine? Mine runs above the gbox X-member, through the PTO shaft hole in the middle X-member, loops under the chassis in front of the fuel tank and exits behind the rear wheel - but then mine's not entirely standard. Quote Link to comment Share on other sites More sharing options...
sotal Posted December 13, 2007 Share Posted December 13, 2007 I bent the new one I fitted using a bit of scaffolding and some gentle heat, it now is tucked up right at the side under the highest point of the cross member if that makes sense, it used to go under far too low and often got caught and split - that's why I needed a new one, the new one hasn't been touched yet with a good amount of off-roading Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 15, 2007 Share Posted December 15, 2007 I ran one out under the front wing as usual diesel, then up thru wing top like snorkel then along top of sun visor, into muffler and then upwards into air facing rearwards if that makes any sense Quote Link to comment Share on other sites More sharing options...
