firemannotsam Posted December 13, 2007 Share Posted December 13, 2007 Hi, I need a wiring multiplug for my airflow meter as mine has cracked and is falling apart and currently held on with tape and cableties! It's a Lucas 3AM airflow meter and the multiplug has 3 wires coming out of it going to the engine loom. Vehicle is a 1998 built Discovery V8 3.9 EFI. UK spec Anyone know where I might get one of these as it wont last much longer! Land Rover want £250+ for the complete engine loom, breakers want £100 for loom - don't want to pay that for a simple multiplug!!! Any help would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
teabag Posted December 14, 2007 Share Posted December 14, 2007 Although I havent this problem, I can see what u mean for such a major componant it's very flimsy not even a rubber shroud over the plug. All I can suggest is have a look in a Maplin shop or RS or Farnell componants on line..Have you try'd a repair with this 'apoxi putty' thats on the market, u know the one that has two parts which u cut and mix together, U can then form form a new shell around the existing cracked one. Just a thought. Regards Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 14, 2007 Share Posted December 14, 2007 Do you mean this sort of thing: In which case you need Vehicle Wiring Products - don't forget to buy terminals & a rubber boot. And if you don't mean that sort of thing, post a picture I'm sure we can find the right bit. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted December 14, 2007 Share Posted December 14, 2007 These are also available form from polevolt, who are often a little cheaper than VWP..................http://www.polevolt.co.uk/ Ian Quote Link to comment Share on other sites More sharing options...
firemannotsam Posted December 14, 2007 Author Share Posted December 14, 2007 Hi guys thanks for your input, it looks like VWP's have the correct one - in fact the one in the picture you sent(left one) Fridge looks the one. I will order one up and some terminals etc - will let you know if iiy does the trick. Thanks again guys Lindley Quote Link to comment Share on other sites More sharing options...
firemannotsam Posted December 21, 2007 Author Share Posted December 21, 2007 Hi guys thanks again VWPs had the correct one and fitted it today, thanks for saving me a packet! Firemannotsam Quote Link to comment Share on other sites More sharing options...
