bush doctor Posted January 9, 2008 Share Posted January 9, 2008 Can anyone point me in the rite direction before i go mad with the tools. The interior lights on my 97 110 CSW dont work when I open the doors, they work if switched on but not when the switch is in the centre position!!!!!!!! Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 9, 2008 Share Posted January 9, 2008 Is this a trick question bushy Ok, i'll bite,, check the door post switches i can see me editiing this later Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 10, 2008 Share Posted January 10, 2008 The door switches are not sealed and get corroded easily. Give them a squirt with WD40 or similar. Quote Link to comment Share on other sites More sharing options...
bush doctor Posted January 10, 2008 Author Share Posted January 10, 2008 Thanks Tim and Jim. Not a trick I've took one of the door switches out and earthed the wire still no good Quote Link to comment Share on other sites More sharing options...
ciderman Posted January 10, 2008 Share Posted January 10, 2008 When you say "Lights" I take that more than one is not working , So that may rule out what I had in mind . Quote Link to comment Share on other sites More sharing options...
bush doctor Posted January 10, 2008 Author Share Posted January 10, 2008 When you say "Lights" I take that more than one is not working , So that may rule out what I had in mind . There are 2 lights 1 front 1 back with both lights switched to the centre position and all the doors open still no light but they both work when switched to the on position Quote Link to comment Share on other sites More sharing options...
western Posted January 10, 2008 Share Posted January 10, 2008 Wiring diagram shows both lights connected to earth on header joint K109. power feed on purple wire to passenger compartment fusebox Fuse 2. & connected to the Alarm ECU D111 on a purple/white wire door switches also go to the D111 [Alarm ecu] on a Purple/Blue wire Left door & Slate/White wire Right door, rear end door also on Purple/Blue to D111. rear side door switches as for rear end door switch. hope that helps Quote Link to comment Share on other sites More sharing options...
bush doctor Posted January 10, 2008 Author Share Posted January 10, 2008 Wiring diagram shows both lights connected to earth on header joint K109.power feed on purple wire to passenger compartment fusebox Fuse 2. & connected to the Alarm ECU D111 on a purple/white wire door switches also go to the D111 [Alarm ecu] on a Purple/Blue wire Left door & Slate/White wire Right door, rear end door also on Purple/Blue to D111. rear side door switches as for rear end door switch. hope that helps It helps but makes it more complicated than I was hoping. Where is the alarm ecu located? infact how is the alarm activated? Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2008 Share Posted January 11, 2008 The Alarm ecu is behind the instrument pack attached to the bulkhead adjacent to the ignion switch. & here's the interior lights wiring diagram. Quote Link to comment Share on other sites More sharing options...
bush doctor Posted January 11, 2008 Author Share Posted January 11, 2008 Thanks Ralph Quote Link to comment Share on other sites More sharing options...
