Boot Posted January 10, 2008 Share Posted January 10, 2008 Hi, Could somebody kindly advise me as to how I could get water in to my fuel - inadvertently that is. This evening while driving my fuel filter light has flickered on and off for some time. Owner's Handbook states this "indicates the presence of excessive amounts of water in the fuel" and to seek qualified assistance at my next earliest convenience (which would be now). Before you ask... I know the price of fuel is ridiculous but no, I haven't been trying to water it down! Should I be looking at replacing the fuel filter? If so, I've checked the technical archive, is it as easy as it looks? I'm a novice when it comes to tinkering with the workings an' all. 1999 110 CSW TD5. 95k. 9k travelled since last service. Cheers, Gareth Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 10, 2008 Share Posted January 10, 2008 It could come from condensation in the tank (yours or the filling station), and IIRC fuel does contain a percentage of water in it. Td5 water sensors (mounted on the bottom of the fuel filter) are known to be troublesone... as such, the later Td5's don't have it, so you could just change the fuel filter and unplug the sensor. Quote Link to comment Share on other sites More sharing options...
pongo Posted January 10, 2008 Share Posted January 10, 2008 Of course, it might be that you have got some water in there, so use the drain; on the bottom of the filter, the sensor can be partially unscrewed to drain off any water (which being more dense than fuel, will be at the bottom). THe filter is also mounted where it gets covered in crud, so check the intergrity of the electrical connection; open it, clean it, then reassemble with a smear of vaseline on the seal. If it still plays up, you can replace the sensor (not expensive), or just ignore it. Quote Link to comment Share on other sites More sharing options...
JST Posted January 10, 2008 Share Posted January 10, 2008 as above try draining the water, if theres none in it, expect a faulty switch. if your is the original switch then its done well to last so long, IIRC that year 99/00 was the worst for it. i had 3 of them! ('99) Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 10, 2008 Share Posted January 10, 2008 If you disconnect the switch, then you can use the cheaper diesel filter from a Tdi and save some cash Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 10, 2008 Share Posted January 10, 2008 99% sure to be the sensor. That's why the light is there, to indicate a defective sensor Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 10, 2008 Share Posted January 10, 2008 In the RAF, we used to have a poster on the wall showing a rather stupid-looking guy surrounded by railway wheels. The caption said 'Here is Fred the wheeltapper. They changed many wheels before he found out his hammer was cracked' I once changed the complete injection system on a Harrier because someone had stolen the bulb out of the electrician's test lamp and battery. It wasn't funny at the time..... Quote Link to comment Share on other sites More sharing options...
Boot Posted January 10, 2008 Author Share Posted January 10, 2008 Great! Thanks for the advice folks. I'll have a tinker at the weekend. Pleased to hear it's nothing to worry about. I'll post back my findings. Cheers, Gareth Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 10, 2008 Share Posted January 10, 2008 In the RAF, we used to have a poster on the wall showing a rather stupid-looking guy surrounded by railway wheels. The caption said 'Here is Fred the wheeltapper. They changed many wheels before he found out his hammer was cracked' I once changed the complete injection system on a Harrier because someone had stolen the bulb out of the electrician's test lamp and battery. It wasn't funny at the time..... It's bluddy funny now though Quote Link to comment Share on other sites More sharing options...
