TripTrick Posted January 12, 2008 Share Posted January 12, 2008 Hi All, I would like to track where my Series IIA 1-Ton 109" Land-Rover comes from. Where on the Chassis can I locate the Chassis Number as the one on the Registration papers seems to be one that was assigned when it was imported and does not tie up to what it should be IMHO? Thaks alot. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 13, 2008 Share Posted January 13, 2008 I think it's the same place as on a s3 - that is on the outside of the drivers side dumb iron on the top edge of the triangular bracket that the bolt for the leaf spring passes through. Les. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted January 13, 2008 Share Posted January 13, 2008 Yes. Although in this case, 'Drivers side dumb iron' is ALWAYS the Right Hand Side dumb iron (as viewed from the drivers seat), whether the driver is actually seated on the Right or the Left of the vehicle. Just being pedantic as this is Forum can be read in both Right and Left hand drive countries. I'm told this picture originated from Haynes, if so credit to them, BUT if it isn't there, also look a little lower, on the same plate, below the level of the chassis member. http://www.s2cforum.com/forum/index.php?ac...tach=3689;image This thread contains picture of an actual number, http://preview.tinyurl.com/2l22jl Cheers. Quote Link to comment Share on other sites More sharing options...
92.9 Posted January 19, 2008 Share Posted January 19, 2008 In all the years I've been into Land Rovers I have never seen a chassis number stamped on a Land Rover chassis! I don't know if they vary in their position, get painted over or welded over, but I've yet to actually see one! Quote Link to comment Share on other sites More sharing options...
