help with splines
wkw90
Ah Mr Wuuuuuuuuurrrrrrrrzzzzzzzzzzle, it be not so simple as that - my RR is 10 spline metric :)
The ONLY way to be certain is to pull a half shaft which, as Luke says is a 10 minute job at most.
Having said all that, if the axle is an 88 RR one and unmolested it will be 10 spline. Change over for the RR was 1992 ish.
