wkw90 Posted February 9, 2008 Share Posted February 9, 2008 Whats the best way to remove the oil seal on 3.5 v8 timming cover its stuck fast and i don't want to do any damage ... Quote Link to comment Share on other sites More sharing options...
Scotian Posted February 9, 2008 Share Posted February 9, 2008 I always find, if in doubt, lump hammer and chissel will fix the problem You would be suprised what I've "fixed" with that meathod Sorry if that wasnt much help Quote Link to comment Share on other sites More sharing options...
Orange Posted February 9, 2008 Share Posted February 9, 2008 I don't know how big the hole is, but a large socket, a hammer and a piece of wood (put over the socket so you aren't striking the socket with the hammer) usually drift that sort of thing out. Short of that, a brass drift and a hammer and some careful persuasion should do it. HTH Adrian Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 Thanks guys but due to wear in the oil pump housing i will need a new cover anyway Still on the bright side thats that problem solved Paul Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 9, 2008 Share Posted February 9, 2008 Did mine yesterday, came out easy with a seal pulling tool: Which has proved to be £5 well spent. You do know it only comes out from the front, don't you? Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 Did mine yesterday, came out easy with a seal pulling tool: Which has proved to be £5 well spent. You do know it only comes out from the front, don't you? Yep got it out in the end with a hammer , and now just ordered a seal puller tool Paul Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 9, 2008 Share Posted February 9, 2008 Fridge, how are these used ? Do you just hook it inside the seal and use the housing around as a fulcrum to lever it out ? Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted February 9, 2008 Author Share Posted February 9, 2008 Fridge, how are these used ? Do you just hook it inside the seal and use the housing around as a fulcrum to lever it out ?Mo You can have a go on mine when it gets here !! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 9, 2008 Share Posted February 9, 2008 Fridge, how are these used ? Do you just hook it inside the seal and use the housing around as a fulcrum to lever it out ? It depends on the situation but you can lever against the hosing, or if you're worried about damaging it, place something across the gap to lever against. I find it's much better at removing seals than prying with a screwdriver due to the shape of the end, it actually pulls it out. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 9, 2008 Share Posted February 9, 2008 Cheers FF, I think I'll add one to the toolset too Mo Quote Link to comment Share on other sites More sharing options...
