MOT TESTING
enduro1972uk
I have a 2002 Discovery ES which i took for its test yesterday, when they checked the brakes on the rolling road brake tester (rollers) i asked if it was ok to do so.
In the past i have been to two different test centres who have took the car out on the road and tested the brakes with some device they had with them.
Can anyone point me in the right direction, is it ok to use the rolling road? If not could it have caused any damage to my car?
As far as Freelanders are concerned, I was told that you can't test cars with permanent 4 wheel drive properly on a rolling road since, for example, if you put the front wheels on the rollers then the back ones will try to drive the car forward or back and if you apply the handbrake to stop it then you get a false (high) reading for the front wheels. The place I go to for an MOT use the old fashioned brake meter on the floor. Similarly you can't recover a broken freelander by lifting the front wheels you either use a flat bed or tow it. Hope this helps.
If it has a LT230 transfer box (which yours will have) its fine. Freelanders and Rangerovers with the borgwarner transfer box (viscous coupling) have to be teated with the Tapley meter on the road. The ctr diff on yours will be fine with this. The only issue would be Traction control playng up but the brake tester rollers only turn at 1.5mph so it doesn't effect it.
Vosa did say that all L/R's should be teated on the road at one time because it was easier than listing which were OK and which wern't but now they say if they have an open ctr diff then they can be tested on the rollers.
