VIN confusion
Hi,
I am looking at buying a landy next week (hooray) but the VIN doesn't match up with the registration plate and I am getting confused.
The VIN is:
SALLDHMD7SA******
Which as far as I can work out a:
SAL Manufacturer code: Land Rover
LD Model: Defender (for early models: Ninety, or One Ten)
H Wheel base: 110 inch
M Body type: 4-door station wagon (LWB)
D Engine type: 2.5 litre petrol, carburettor
7 Steering and transmission: Right-hand drive (RHD), 5-speed manual (LT85, LT77, LT77S, R380 or other)
S Model year: 1995 (US market, and CKD production only)
A Assembly location: Solihull, UK
****** Serial number
It is the model year that is confusing me as this is a G reg registered on 19.03.1990
The owner has replaced the engine with a 200tdi.
thanks,
/mad
S wasn't used in the model range identifier
1989 model year is F ---- mines a 1989 'G' reg 110CSW & has FA in it's chassis number.
1990 model year is G
1991 is H
1992 is J
1993 is K
1994 is L
1995 is M
1996 is T
1997 is V
1998 is W
Does the VIN plate on the brake servo mounting agree with the stamped in chassis number on the lower front right chassis ? if not then walk away from it, if all agree & they agree with the V5 DVLA reg document, it should be fine.
USA vehicles were built in UK & CKD vehicles should show a F = overseas assembly from CKD set of parts.
Thanks Western, I will check when I go to collect.
The VIN he supplied me from the V5 doesn't match the number plate. Also he said the date on the V5 was 05/04 but I have it down as last being transferred on 08.05.2001.
But then again the HPI check I did said the mileage was inconsistant as well. It says it was 65,000 in 2000 but it is now 136K in 2008.
8 years at an average of 12K is 96K so it sounds well within range.
Everything else matches the HPI check.
The only way to be certain is when I go to collect, but wanting to get as much sorted before I drive 2 hours to collect it.
thanks.
Ralph
Some of the US market vehicles do have funny VIN's especially in the model year range, though I don't have details to hand. But that type of vehicle was never built for the NAS market AFAIK :huh:
I would do extra homework on the background before parting with cash "just in case"!
Guest diesel_jim
I'd leave it alone, especially with ^^^^^
sounds like a "bista"... bits of vehicle and bits of paperwork.
Ralph
Can only go on the info I've got to hand & S in the VIN is not used, but your probably more upto date than my info.
if not sure leave it as DJ says above.
just done a google search for Land Rover chassis numbers & found this website,
http://www.lrfaq.org/FAQ.3.Chassis_Numbers.html
the USA part of the list might explain the S in the subject 110's VIN.
Ok,
the brake servo, chassis and V5 VIN's all match ok.
The 05/04 number is not the date but the number in the circle on the V5 so that makes sense. I have the same on mine.
The date on the V5 matches the last keeper details I saw on Autotrader.
So after my initial panic, is sounds ok.
thanks for the input and advice.
/mad
