V8RRC Posted March 19, 2008 Share Posted March 19, 2008 Hi All, I am after a bit of advice regarding ABS faults! At work we have a 1997 (p-reg) 300 tdi xs Discovery which the ABS was working fine on but one day while out on a job with a 16ft trailer in tow the ABS light decieded to come on & stay on! After being cautious during the rest of the journey & returning to the yard it was obvious that the ABS was not working! After some messing about it was noticed that the stop light were also not working, so after investigation the 4 pin brake light switch turned out to be faulty. I see looking at the diagram 2 pins do the stop lights & 2 pins go to the ABS unit. The switch has now been replaced but the light still stays on & no ABS! From what we can see all the ABS sensors are seated ok! So does anyone have any ideas on what the fault could be? or since the switch has been replaced does the system need to be reset? & if so is there a way of doing this without going to a main stealer? Thanks for any help or advice! Regards, Quote Link to comment Share on other sites More sharing options...
white90 Posted March 19, 2008 Share Posted March 19, 2008 You can get an independent to read the codes then see what is wrong The sensors are the same as used on Trucks and can be had for nearly a 3rd of the L/r cost just get the Wabco part number from the sensor. We had a sensor go open circuit on Vals old Discovery Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 19, 2008 Share Posted March 19, 2008 Don't know if it is the same system as a RRC, but you can check fault codes using a "blink test". Should be in the tech archive I think. If not, search for an ABS post by Geoff Beaumont. Saved me a pretty penny with my ABS. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 19, 2008 Share Posted March 19, 2008 Later system I think Charles Pete Rowe sorted mine for me with his testbook Quote Link to comment Share on other sites More sharing options...
V8RRC Posted March 19, 2008 Author Share Posted March 19, 2008 Thanks for the input guys! Bish I believe Tony is correct in saying it is a later system! I had looked at Geoff's ABS write up & it does not seem the same! We will have to try a local independent & get the code(s) read! Thanks Again, Quote Link to comment Share on other sites More sharing options...
mpb Posted March 20, 2008 Share Posted March 20, 2008 A friend diagnosed the ABS fault on there "M" reg disco using the paper clip method. We then put the fault code into google & found the fault. Turned out to be one of the wheel sensors need replacing. Even told us which one. Quote Link to comment Share on other sites More sharing options...
