smo Posted March 20, 2008 Share Posted March 20, 2008 How do you remove the plug from the top radiator hose, it appears to have a screwdriver slot, but this does nothing, and i cant remove it!!! Help! Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted March 20, 2008 Share Posted March 20, 2008 Why do it, release another hose to let the air out. When I loosened mine it leaked and I couldn't stop it. Renewed the hose in the end. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted March 20, 2008 Share Posted March 20, 2008 3 or 4 lbs of high exploxsive could work? Sorry Smo........... I'll get my coat Quote Link to comment Share on other sites More sharing options...
smo Posted March 20, 2008 Author Share Posted March 20, 2008 3 or 4 lbs of high exploxsive could work?Sorry Smo........... I'll get my coat With the week i've had chasing little electrical gremlins i wouldnt refuse, however she is now working so i need to get some coolant in, and bleed up the power steering too and then i can drive her, for the first time ever!!!! Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted March 20, 2008 Share Posted March 20, 2008 With the week i've had chasing little electrical gremlins i wouldnt refuse, however she is now working so i need to get some coolant in, and bleed up the power steering too and then i can drive her, for the first time ever!!!! Try and get the largest piece of flat steel bar or indeed a large cold chisel that will fit in the slot and turn it with an adjustable spanner to undo it... then get one of the nice alloy ones from X-Enginering to replace it with!- you can get a forum discount via the link in SimonR's postings Quote Link to comment Share on other sites More sharing options...
freeagent Posted March 20, 2008 Share Posted March 20, 2008 I put a suitable sizes pair of stillsons around it and got it out that way.. Replace with either a nice red one from X-Eng, or a brass BSP blanking plug from any good plumbers merchants... Quote Link to comment Share on other sites More sharing options...
smo Posted March 20, 2008 Author Share Posted March 20, 2008 Got fed up and took the hose off in the end...problem is its still not circulating Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted March 20, 2008 Share Posted March 20, 2008 I thought the top hose bung on 300tdi was a different size to the radiator bung... Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 21, 2008 Share Posted March 21, 2008 I think smo is talking about the little plastic screw that is actually moulded into the TD5 top hose. This is what happens when you don't specify what vehicle it is you are talking about. Most of the replies above are about Tdi plastic plugs. I would leave the screw alone if it doesn't want to come out and take the hose off instead. I you 'screw up' the screw it will be a new top hose and they are very expensive for what they are. Oh, and the plug in the top of the thermostat housing and the radiator plastic plug on a Tdi are exactly the same size. We replace both with brass items. Quote Link to comment Share on other sites More sharing options...
