jericho Posted March 21, 2008 Share Posted March 21, 2008 Its time to fit an ARB locker and High output compressor in my pickup/truckcab. I dont want the compressor in the cab with me due to lack of space and noise,so ideally I would put it on the wheelbox in the rear tub.Is this sensible? Should I protect it from the weather? Put it in a box? What do others do? Quote Link to comment Share on other sites More sharing options...
Jurriaan Posted March 21, 2008 Share Posted March 21, 2008 In a Disco I just bought for parts it was behind the rear seats, not covered. Don't think you should cover it up too much because of cooling? But leaving it out in the open on a pickup wouldn't be my choice also. In m'n Defender I'll be mounting it below the passenger seat, next to my Webasto heater. Quote Link to comment Share on other sites More sharing options...
jericho Posted March 21, 2008 Author Share Posted March 21, 2008 Yes,I thought of the seat box,buy mine are far from waterproof,and have been full of water on several occasions,so it needs to go higher up than that. Quote Link to comment Share on other sites More sharing options...
TomG Posted March 21, 2008 Share Posted March 21, 2008 I had mine mounted in the rear tub, went through 2 x ARB compressors, motors kept seizing up - i think water runs through where the wires go into the motor. It'd probably be fine in a box or in the cab. Now replaced with Sanden A/C pump which takes it's air feed from the snorkel. Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 21, 2008 Share Posted March 21, 2008 if it's just for the ARB, fit the waterproof ARB mini compressor. It's cheaper, and will work even when submerged with a breather for the air intake. Cheers Steve Quote Link to comment Share on other sites More sharing options...
JST Posted March 22, 2008 Share Posted March 22, 2008 Mines in one of the rear lockers above the wheel arch on the truck cab. C4x4 run theres uncovered in the back Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 22, 2008 Share Posted March 22, 2008 Those arb compressors are handy for blowing the dust of the steering wheel eh ! James Quote Link to comment Share on other sites More sharing options...
JST Posted March 23, 2008 Share Posted March 23, 2008 Those arb compressors are handy for blowing the dust of the steering wheel eh ! James they certainly are, i may even redirect the blast towards your paperwork/filing system! Quote Link to comment Share on other sites More sharing options...
Old Spot Posted March 23, 2008 Share Posted March 23, 2008 Put it in an ammo box , then you can open it for ventilation or close it for waterproofing , now were did I get that idea? Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 23, 2008 Share Posted March 23, 2008 they certainly are, i may even redirect the blast towards your paperwork/filing system! Quote Link to comment Share on other sites More sharing options...
jericho Posted March 23, 2008 Author Share Posted March 23, 2008 Excellent - thanks,I might just do that. Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 25, 2008 Share Posted March 25, 2008 This thread has given me thought to how waterproof these little pumps are , and as mine is situated behind the passenger seat and not much space to put it anywhere else sensible it made me a tad concerned After a truckful of water at one of James` recent events I had a near miss with the compressor , I did this Sealed the motor and the crank housing with a quality RtV sealant , Shrink wrapped a rtv filled sleeve around the wiring harness , Cut an m14 thread into the inlet and fitted a 12mm coupling with extended pipe with a filter that extends up to the top of the seat headrest , Fitted a 1/8 bsp 5mm coupling with extended breather to the crankcase . Ive checked the amp draw before and after the breathers fitted and there is no change so i guess the breather is not makeing the pump work harder . Quote Link to comment Share on other sites More sharing options...
JST Posted March 26, 2008 Share Posted March 26, 2008 deeper water needed is that what you are saying? Quote Link to comment Share on other sites More sharing options...
ciderman Posted March 26, 2008 Share Posted March 26, 2008 deeper water needed is that what you are saying? Well, I guess im prepared for it a bit better now , Only thing is my wetsuit dosnt fit any more mind you its been 15 years . Quote Link to comment Share on other sites More sharing options...
