Dana 35
Phantom
Help please.........
I've got to rebuild / repair a Dana 35 axle on the rear of a Jeep ( Sorry I know it's not LR...........)
The pinion bearings have loads of play, you can grab the rear prop and get about 25mm of lateral movement - and of course the associated noise's and whine's when driving.
Any tips / advice / special tools req etc etc???
Thanks in advance
Lee
Are you positive its a 35 ................. easy confused with a Chrysler 8.25 ................ and they are renowned for pinion bearing failure.
On our Cherokee mine uttered noises of protest at 80K ........................
A word of warning ......... buy the bearings from BSL etc .............. jeep prices are prohibitive ............. 2 carrier bearings, 2 pinion bearings, two oil seals and the crush washer ........... thats £470 sir ! :blink:
Certainly the 8.25 is not difficult, but you do need to make up a special tool to adjust the carrier bearing preload..........
Ian
Ian
I'm positive its a 35, got an overhaul kit already - anything I need to worry about..............???????
Regards
Lee
Done a Dana 30 (Front Axle TJ) awhile back. All pretty straight forward, though a Dti torque wrench for the Crush sleeve is needed. As you need to set the Rolling torque value as required by manufacture (but not sure if the 35, uses a crush sleeve) A 3/4 Torque wrench can be handy, so you can increment your torque on the crush sleeve, untill you reach the desired rolling torque. Otherwise its a gently does it approach with 1/2" Ratchet.
Hope that helps?
