jcwcooper Posted March 25, 2008 Share Posted March 25, 2008 I have invested in some raised breathers and a Timing cover breather. 4 questions I take it the timing cover goes here 2nd question is another silly one but it needs to be done right which way round does it go? This way....PIC 1 or this way PIC 2 One more thing does anyone know if the Air filter housing is steel or ali, I havent had a chance to take it out and have a look yet, As my crankcase breather pipe has nowhere to attach too and a new one sounds expensive. Thanks Dave. Quote Link to comment Share on other sites More sharing options...
steve_a Posted March 26, 2008 Share Posted March 26, 2008 I'd say your second pic is the outward side for 3 reasons: it looks better; it gives more clearance for the injection pump nut; if you mount it the other way the lip won't let it seal will it? Where did you get it and how much btw? Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted March 28, 2008 Author Share Posted March 28, 2008 Thanks for your reply those were my thoughts but i wondered why bother with the lip, The kit was from David at Llama 4x4 ive popped a link below. The kit seems really high quality its all fitted now. http://www.llama4x4.com/page6.htm Dave. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted March 30, 2008 Share Posted March 30, 2008 so do you put that on and then put a wading plug in the bottom of the timeing case Quote Link to comment Share on other sites More sharing options...
Scotian Posted March 30, 2008 Share Posted March 30, 2008 I thought the gear box and timing case wading nuts needed to be removed for normal driving so that if anything leaks it gets out instead of swimming around inside? So the breather is all very well but you wont know if something is wrong and you will need to keep going under, undoing the plugs and checking for fluids... Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted March 30, 2008 Author Share Posted March 30, 2008 Yep you will still need to check that water is not getting in so you still need to remove the wading plugs. Dave. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 7, 2008 Share Posted April 7, 2008 Yep you will still need to check that water is not getting in so you still need to remove the wading plugs.Dave. where is the gearbox wading plug supposed to go i cant see any where for it Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 7, 2008 Author Share Posted April 7, 2008 Its right on the bottom of the bellhousing at its lowest point. If you cant find it will get you a pic if you want. Dave. Quote Link to comment Share on other sites More sharing options...
western Posted April 7, 2008 Share Posted April 7, 2008 marked location on this picture of my 200Tdi. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 8, 2008 Share Posted April 8, 2008 marked location on this picture of my 200Tdi. ok cheers thought that might be it ive got one in there and its seized in. do they need to come out Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted April 8, 2008 Author Share Posted April 8, 2008 Yes, its pritty important to take them out at least once a week......water can sometimes still find its way in, and also the reason the hole is there is incase of an oil leak the oild can get out, when you finally get it out pop a pit of cooper slip in the threads makes them nice and easy to take out. dont forget the timing cover one too! Dave. Quote Link to comment Share on other sites More sharing options...
