muddy_muppet Posted March 26, 2008 Share Posted March 26, 2008 Sorry if this is the wrong forum. Not vehicle specific, as the 300TDi axle is off a '96 90 I have the possibility of getting a 300TDi axle (with locker) complete, for a '92 Disco, can I just fit the diff n shafts or will I need to fit the complete axle? Thanks MM Quote Link to comment Share on other sites More sharing options...
white90 Posted March 26, 2008 Share Posted March 26, 2008 Fit the complete axle it will be easier and quicker and the casing/etc is 4years younger Quote Link to comment Share on other sites More sharing options...
v8bertha Posted March 26, 2008 Share Posted March 26, 2008 300TDi Discos had a large rubber donut between the diff nose and the prop shaft to help take out a lot of the clunk when taking up drive. Therefore the diff flange will not take a standard prop shaft fitting as found on 90 et all. But... no reason why you couldn't change the diff flange. Not sure if the setup is different for a locking diff, but worth a look just to be on the safe side. HTH Dan Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 26, 2008 Share Posted March 26, 2008 Then again, the axle could have been off a 1996 90 Dan...... Quote Link to comment Share on other sites More sharing options...
v8bertha Posted March 26, 2008 Share Posted March 26, 2008 Then again, the axle could have been off a 1996 90 Dan...... hmmm... do you think maybe I've misread the question?? Quote Link to comment Share on other sites More sharing options...
muddy_muppet Posted March 26, 2008 Author Share Posted March 26, 2008 Thanks for the help.... :whisper mode on: The diff is a detroit locker :whisper mode off: The old 200 axle has new bearings and brakes and I don't really want to change them around. So thought, a diff and shaft swop would be the quickest/easiest option. So can i do it? Quote Link to comment Share on other sites More sharing options...
