mmgemini Posted April 14, 2008 Share Posted April 14, 2008 Ralph Do you have a picture/diagram of a 200Tdi handbrake cable please. Especially the hand lever end. mike Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 14, 2008 Share Posted April 14, 2008 Here ya go Mike: you need the part numbers? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 14, 2008 Author Share Posted April 14, 2008 Thanks Jim No I have a handbrake problem. I think it's in the lever end. I wanted to see what was in that bit. It's not helped because I have a Range Rover lever fitted. The problem is that sometimes when you pull the handbrake it works at two clicks. Next time at six ???? It's an X-Brake. Simon thought it could be the cable falling about. It looks as if he's right. I'm going to have to take things apart tomorrow. mike Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 14, 2008 Share Posted April 14, 2008 Is Jim Ralph Jnr Mo Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 14, 2008 Share Posted April 14, 2008 Thanks JimNo I have a handbrake problem. I think it's in the lever end. I wanted to see what was in that bit. It's not helped because I have a Range Rover lever fitted. The problem is that sometimes when you pull the handbrake it works at two clicks. Next time at six ???? It's an X-Brake. Simon thought it could be the cable falling about. It looks as if he's right. I'm going to have to take things apart tomorrow. mike I have the same problem. There is no way for the cable sheath to be held tight to the underside of the hand brake lever. I've yet to work out how to do it. If you find a way pleas post up your solution Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 14, 2008 Author Share Posted April 14, 2008 Is Jim Ralph Jnr Mo Mo Voltmeter. Do you still want one ?? I have one from a Range Rover mike Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 14, 2008 Author Share Posted April 14, 2008 WALFY Have you a Defender or a Range Rover lever ? mike Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2008 Share Posted April 14, 2008 RRC handbrake from Chassis FA351033, able to show earlier or later if required., & Defender handbrake. just seen this thread, so apologies for not replying earlier. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 14, 2008 Share Posted April 14, 2008 Is Jim Ralph Jnr Mo Much more Jnr.... and better looking to! Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2008 Share Posted April 14, 2008 Much more Jnr.... and better looking to! & hairier Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 14, 2008 Share Posted April 14, 2008 WALFYHave you a Defender or a Range Rover lever ? mike RRC hand brake lever. I've fitted it between the seatbox and my seat. I found it a bit of a struggle with the 6point harness to reach the normal h/brake. Other than this small niggle it's a well worth while upgrade for any 90 driver Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 14, 2008 Author Share Posted April 14, 2008 RRC hand brake lever. I've fitted it between the seatbox and my seat. I found it a bit of a struggle with the 6point harness to reach the normal h/brake. Other than this small niggle it's a well worth while upgrade for any 90 driver Right. Let me take mine to bits in the morning. Provided it stays dry. mike Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 14, 2008 Share Posted April 14, 2008 Mike, If it's the same as the one in the picture on the wanted thread, then yes please. If not, I have several assorted volt meters already, I'm just trying to pair up a couple of 90/110/defender ones. I've amended my signature to clarify what I'm after. Cheers Mo Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 WALFY, Do you still have your Defender handbrake lever ? The plan is. Remove the base from the lever. Bolt that to tuder the bracket that holds the RR lever on. There's a nice tube for the cable to sit in. Pictures later. mike Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 15, 2008 Share Posted April 15, 2008 does your RRC handbrake not hold the hadbrake cable outer sheath then? Mine does. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 does your RRC handbrake not hold the hadbrake cable outer sheath then?Mine does. Aparently not. It's got IIRC a 200Tdi cable fitted to suit the X-Brake. mike Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 Right ..A change of plan.... Well at the moment. Ther cable is threaded at the handbrake end. The plan is to get a nut to fit the thread... bolt the cable to the base of the RR lever. Mage the hole in the seatbox bigger and push the cable through from the top. We shall see..... mike Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 15, 2008 Share Posted April 15, 2008 This is my handbrake, standard '89 RR as far as i know, with a new cable from SimonR. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 Yes Luke. Mine is like that WITHOUT the nut. Thank's to Teesside Industrial Fasterners I now have a nut,,,,,,,,,,, The next job is to stop the rain falling... Then I can re-fit everything.... mike Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 Job, jobbed, thank you everybody for your help. mike Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 15, 2008 Share Posted April 15, 2008 Yes Luke. Mine is like that WITHOUT the nut.Thank's to Teesside Industrial Fasterners I now have a nut,,,,,,,,,,, The next job is to stop the rain falling... Then I can re-fit everything.... mike Likewise. I don't have that nut fitted either. Will have to have a look see about the thread poking through and see if I can locate a nut. Mike, as you have just got the nut any chance you know the size thread or did you do it by trial fitting? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 I walked into Teesisde Industrial Fasteners with the cable. Plonked it on the counter.. "A nut for that please" "What size is it?" "That's why I brought the cable" He took the cable and returned with a nut on it. "What size is the nut" "You don't need to know that". I think he said 15 x 1.5 mm but it could have been 16 x 1.5. I remember the 1.5 bit Now I also lifted the handbrake lever my 5mm by packing it with a piece of ally strip. The hole to clear the cable is 23mm diameter. That gave me a bit more to let the cable bend to the seatbox. HTH mike Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 15, 2008 Share Posted April 15, 2008 Thanks. Will try that in the workshops when I get chance to get the cable off Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2008 Author Share Posted April 15, 2008 I should have added. Because my cubby box is close the the lever and I have the seat on 25mm square alli section. There isn't a lot of room to work there. So.. I built the lever end up, then fitted it through the seatbox and onto the calliper lever. mike Quote Link to comment Share on other sites More sharing options...
