Skanny Posted April 23, 2008 Share Posted April 23, 2008 Hi guys, Can anyone confirm if the rear axle from an L Reg 200 Disco will fit onto a C reg 90? If not a straight swap is there anything else i need to get? Thanks Quote Link to comment Share on other sites More sharing options...
Ivan Posted April 23, 2008 Share Posted April 23, 2008 Pretty sure it will fit OK. I fitted one to my E Reg 90 and it just bolted on. HTH Ivan Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 23, 2008 Share Posted April 23, 2008 Check which direction(s) the shocks point, some are one forward one backward, some are both forward (later) but apart from that it should be nuts & bolts. Quote Link to comment Share on other sites More sharing options...
Scotian Posted April 23, 2008 Share Posted April 23, 2008 I put a 92 Disco axle on my 85 90 (rear)with no problems atall. Quote Link to comment Share on other sites More sharing options...
Ivan Posted April 23, 2008 Share Posted April 23, 2008 Err FF it's a Disco. They both point the same way. Only Rangies had them different ways. At least as far as I know. Rgds Ivan Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 23, 2008 Share Posted April 23, 2008 Correct Ivan. All disco have 2 front shocks and they will fit the 90 no probs. Make sure you get the trailing arms though just in case as there may be a difference in the size of the brakets (but I don't think so!) Quote Link to comment Share on other sites More sharing options...
Skanny Posted April 23, 2008 Author Share Posted April 23, 2008 Many thanks all, Colin Correct Ivan.All disco have 2 front shocks and they will fit the 90 no probs. Make sure you get the trailing arms though just in case as there may be a difference in the size of the brakets (but I don't think so!) Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted April 23, 2008 Share Posted April 23, 2008 Btm Link (trailing arm) are the same Pt No NTC8328. Defender from HA470428 Discovery 1989-98 RR Classic 1986-94 So brackets should be the same. Rod Quote Link to comment Share on other sites More sharing options...
