western Posted May 15, 2008 Share Posted May 15, 2008 Another fine creation from the 'Inventing Shed of Henson' really nice job Les Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 16, 2008 Share Posted May 16, 2008 Nice it certainly is………………. but, Was it gas welded or did you use your nice new MIG ……………… if you didn’t use your nice new MIG are you just going to keep the MIG as an ornament in the living room whilst you struggle on with an archaic technology? Are you going to weld this one on 10mm pi$$ed like the last one ? Well done Les ….nice job Ian Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 16, 2008 Author Share Posted May 16, 2008 It's MIG welded Ian - it would take ages to gas weld metal that thick. Sadly I only use my gas gear if I need to bend as I weld. It was 15mm anyway Les Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 16, 2008 Share Posted May 16, 2008 I only use my gas gear if I need to bend as I weld. Oooerrr.... Or does this prove you stand to attention when you weld..... Better make sure that ramp is working when you come over to sort my rear crossmember.. Can get the car to the right height for you then.... Neil Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 16, 2008 Share Posted May 16, 2008 It's MIG welded Ian - it would take ages to gas weld metal that thick. Sadly I only use my gas gear if I need to bend as I weld. It was 15mm anyway Les I thought is was Mig because the heat pattern is more localised, but I was surprised at how little splatter you have, I guess the metal was really clean and you are using a heavy Ar Co2 mix................. Yeah ............. this time, measure ten times and weld once BTW:I have ordered a new welding toy ................... a post will follow in about a month................. Ian Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 16, 2008 Author Share Posted May 16, 2008 I was surprised at how little splatter you have I ain't Britpart y'know New welding toy? If you start to show off I'll mess with your signature Ian Les Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 16, 2008 Share Posted May 16, 2008 I ain't Britpart y'know Les The new toy will require a 50A breaker on single phase Ian Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted May 17, 2008 Share Posted May 17, 2008 The new toy will require a 50A breaker on single phase So when my lights dim somewhat I know you are welding then Ian??!! Quote Link to comment Share on other sites More sharing options...
