bigjohn Posted May 5, 2008 Share Posted May 5, 2008 Hi all,i have just purchased my 4th landrover, a 300tdi es disco in mettalic red. couple of questions please- 1/ i need to change the exhaust system. if i order a pre-cat system complete with the downpipe will it fit straight on a cat equipped one, removing the cat? 2/ i dont know when the cambelt was last done,are there any markings to show if it has the modified wheels/cover fitted? if not what kit should i get,or do i need to get it taken apart to see what's on there?any recomendations for cambelt fitters in the oxford area?cheers,john. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 5, 2008 Share Posted May 5, 2008 Yes it should (downpipes should be interchangeable) but beware that some aftermarket exhausts are different design so on some of those you can only change the whole system unless you find the right bit from the right maker! Shouldn't be a problem if you are changing the whole thing though. There should be a blob of yellow paint on the timing case if it has been modded but the only way to tell 100% is to take the front cover off and have a look. Quote Link to comment Share on other sites More sharing options...
ally-74 Posted May 5, 2008 Share Posted May 5, 2008 Hi John and welcome to the forum Alex Quote Link to comment Share on other sites More sharing options...
bigjohn Posted May 5, 2008 Author Share Posted May 5, 2008 Yes it should (downpipes should be interchangeable) but beware that some aftermarket exhausts are different design so on some of those you can only change the whole system unless you find the right bit from the right maker! Shouldn't be a problem if you are changing the whole thing though.There should be a blob of yellow paint on the timing case if it has been modded but the only way to tell 100% is to take the front cover off and have a look. i can't see any yellow paint,if i take the cover off,what differences am i looking for? Quote Link to comment Share on other sites More sharing options...
python Posted May 5, 2008 Share Posted May 5, 2008 hi john, B) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 5, 2008 Share Posted May 5, 2008 i can't see any yellow paint,if i take the cover off,what differences am i looking for? see here http://forums.lr4x4.com/index.php?showtopic=12788 Quote Link to comment Share on other sites More sharing options...
allegedly Posted May 5, 2008 Share Posted May 5, 2008 Hi bigjohn, welcome, got a red one too! Funny how many red ones you see once you get one! Quote Link to comment Share on other sites More sharing options...
bigjohn Posted May 6, 2008 Author Share Posted May 6, 2008 thanks for the welcome's, and a big thanks to bogmonster for the link.looks like cover off time shortly.....cheers,john. Quote Link to comment Share on other sites More sharing options...
