bushwhacker Posted May 8, 2008 Share Posted May 8, 2008 Any body know which type of car would have a 12volt electric fan that will do a series 2.5na d? I would like to mount it between the rad and front grill that is to suck air in. Any suggestions welcome. Quote Link to comment Share on other sites More sharing options...
rjblank Posted May 8, 2008 Share Posted May 8, 2008 I have a 'lectric fan from a BMW 530 (V8) in my Landy. It takes up most of the radiator. It moves lots of air... Quote Link to comment Share on other sites More sharing options...
kingdong Posted May 8, 2008 Share Posted May 8, 2008 peugeot ones normaly do fine if you don't off road it. s11a swb bronze green. soon to have a 200 tdi Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 8, 2008 Share Posted May 8, 2008 Tape measure + scrapyard = sorted Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 10, 2008 Share Posted May 10, 2008 Mondeo fans are supposed to be a pretty easy fit. Les. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted May 10, 2008 Author Share Posted May 10, 2008 Mondeo sounds good. Quote Link to comment Share on other sites More sharing options...
kingdong Posted May 10, 2008 Share Posted May 10, 2008 are the mondeo fans good for a 200 tdi conversion into a s11a graham. soon to have a 200 tdi in. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 11, 2008 Share Posted May 11, 2008 Most single fans over 30cm will be sufficient. The only consideration is how hard it is/will it fit. A small fan will run for longer to reduce coolant temperature - whereas a large fan will not. Most fans are not designed to run for long periods, so if you fit a small fan, then expect it to need replacing in the future - due to bearing failure. A few other things you might need to consider- Push (outside the radiator), or pull (inside the engine bay). Current draw (a lot are 20-amps running, but twice that for start-up. Thermal switch controlled only, or override as well. Single speed or twin speed motor. Don't use the Kenlowe type of fan switch - they are real rubbish and fail in the off position. You then take a chance of your engine overheating, and have to bypass the switch at the side of the road to keep your engine cool (but then have the problem of the fan running all the time until you fix it). X-Eng fan switch is easy to fit, very reliable, and the switch itself is available from any motor factors (even Halfords ) Les. Quote Link to comment Share on other sites More sharing options...
mbconfuse Posted May 13, 2008 Share Posted May 13, 2008 Don't use the Kenlowe type of fan switch - they are real rubbish and fail in the off position. You then take a chance of your engine overheating, and have to bypass the switch at the side of the road to keep your engine cool (but then have the problem of the fan running all the time until you fix it).X-Eng fan switch is easy to fit, very reliable, and the switch itself is available from any motor factors (even Halfords ) Les, Ive had exactly what you describe above with the Kenlowe switch, and opted for a X-Eng switch. Thing is it seems like its taking too long to switch on and i dont know if i trust it. If left ticking over how long would you expect a Rover v8 to take to get up to temperature before it needs the fan? I should probably get the thermometer re-wired up! Mike Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 13, 2008 Share Posted May 13, 2008 You need to know at what tempertaure the coolant is when the fan switches on in order to determine if it's working correctly. A fixed or viscous fan runs all the time when it doesn't actually need to, so an electric fan coming on occasionally might seem odd, but is in fact ok. If you fit an electric fan to a 300TDi for example - you would have to try very hard to get the fan to come on at all. Les. Quote Link to comment Share on other sites More sharing options...
