Francis Posted May 9, 2008 Share Posted May 9, 2008 Hi everyone. I have just replaced my alternator, and still there are drops in power as I turn the steering wheel when not moving, like a belt is slipping or the power steering is not functioning properly. Each time the power steering becomes weak as I turn the steering wheel, the red battery light comes on. Can anyone give me any ideas? Is it as simple as the power steering pump? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 9, 2008 Share Posted May 9, 2008 Sounds like the belt is loose to me! What exact vehicle do you have? (it always helps! your profile pic shows a 110...) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 9, 2008 Share Posted May 9, 2008 Belt slipping, it's the only common thing I can see between the alternator & PAS pump. Quote Link to comment Share on other sites More sharing options...
Francis Posted May 10, 2008 Author Share Posted May 10, 2008 It's a discovery 200TDi. I am going to go outside to have a look right now regards the belt slipping. Quote Link to comment Share on other sites More sharing options...
Francis Posted May 10, 2008 Author Share Posted May 10, 2008 I see what you mean. The pas is drive on the same disc as the alternator, and the belt is pretty worn/loose. What kind of effort is required to switch belts? What do I have to remove. is there an 'easy' way! I have just done the alternator and obviously to have steering that doesn't squeal or fight me would be great! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 10, 2008 Share Posted May 10, 2008 Have you tried adjusting the slack out of the PS belt? Quote Link to comment Share on other sites More sharing options...
Chris9119 Posted May 10, 2008 Share Posted May 10, 2008 Check the PAS pump bearing...., sometimes, when on the way out theres a bit of movement which causes these symptoms. You will have to slacken the belt to check it. Chris Quote Link to comment Share on other sites More sharing options...
Francis Posted May 10, 2008 Author Share Posted May 10, 2008 How do I slacken the belt? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 11, 2008 Share Posted May 11, 2008 The PAS pump pivots on it's own mounting plate. Look slightly to the left of the pulley wheel and you will see what I mean. Slacken the three 13mm bolts (they may also be 10mm). To change the belt you need to lever the pump towards the left, and opposite to tension it. Use a pry bar or big screwdriver to lever the pump/tension the belt, and while maintaining the pressure - tighten the bolts. Les. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 11, 2008 Share Posted May 11, 2008 The mounting plate has a 1/2" square hole in it, so you can use a drive bar and extension to tension the belt. That looks like a defender 200tdi, i was wondering if the bracket was the same. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 11, 2008 Share Posted May 11, 2008 Yes it is a Defender Luke. Les. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 11, 2008 Share Posted May 11, 2008 so, is a discovery PS pump bracket the same? Quote Link to comment Share on other sites More sharing options...
