Matt B Posted May 11, 2008 Share Posted May 11, 2008 We are having a debate on the local club forum because I posted some pictures of my testing of "the turd" and people think that the tyres are fitted the wrong way round - I am not totally stupid and have followed the direction arrows on the tyre. Has anybody else noticed that the tread goes in the opposite direction to most other brands or do I just have defective tyres? M Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 12, 2008 Share Posted May 12, 2008 look from the front tyres should look like this yes thats a dumper tyre but the tread works best that way and i'd gess the Anacondas work the same i've never had a tractor run away with the tyres pointing up hill (backing down) but have had many take off down the hill when driving down(not nice) Quote Link to comment Share on other sites More sharing options...
Matt B Posted May 12, 2008 Author Share Posted May 12, 2008 look from the front tyres should look like this yes thats a dumper tyre but the tread works best that way and i'd gess the Anacondas work the same i've never had a tractor run away with the tyres pointing up hill (backing down) but have had many take off down the hill when driving down(not nice) That's the problem - the direction of rotation marked on the tyre runs it in the opposite direction to that. I don't know whether to run them as specified on the tyre or listen to the hearsay of fellow enthusiasts. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 12, 2008 Share Posted May 12, 2008 as its only a case of swoping left to right to put them the other way round try the both ways see what you think your the one going to be driving it after all. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted May 12, 2008 Share Posted May 12, 2008 Same as boggers ................. IIRC...........In the pic the correct rotation is clockwise......... i.e. the tyre traveling towards you. An easy way to remember is that the pointy bit of the V should hit the road first.............. most directional tyres have a V pattern albeit some are a bit vague....... Ian Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted May 12, 2008 Share Posted May 12, 2008 look from the front tyres should look like this yes thats a dumper tyre but the tread works best that way and i'd gess the Anacondas work the same i've never had a tractor run away with the tyres pointing up hill (backing down) but have had many take off down the hill when driving down(not nice) You've had tractors take off with you down hills? how is that related to tyres? plus what tractors do you have? Zetors? LOL! Quote Link to comment Share on other sites More sharing options...
Matt B Posted May 12, 2008 Author Share Posted May 12, 2008 Thanks guys - I think a harshly worded letter to Greenway is in order, the rotation arrow definitely points against the grain. Quote Link to comment Share on other sites More sharing options...
nas90 Posted May 12, 2008 Share Posted May 12, 2008 Thanks guys - I think a harshly worded letter to Greenway is in order, the rotation arrow definitely points against the grain. Surely depends on whether the tyre is driving or driven? If on a muck spreader driving the spinners then the other way around? If your tyres were designed by Greenway to drive implements maybe they are correct with their directional arrows Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted May 12, 2008 Share Posted May 12, 2008 If the tread are backwards (pushes the mud into the tread) it could have potentially lethal affects in wet conditions as the water will be forced into the wheel and have nowhere to go except for pushing the wheel off the ground loosing grip, steering and breaking and cause potentially lethal / fatal concequences (worse case senario mind) Quote Link to comment Share on other sites More sharing options...
Matt B Posted May 12, 2008 Author Share Posted May 12, 2008 My way of looking at it is that if I have a prang with the tyres fitted to maunufacturers recommendation then I can come back on Greenway - if I put them on with the arrow pointing the wrong way... Quote Link to comment Share on other sites More sharing options...
smo Posted May 12, 2008 Share Posted May 12, 2008 Thanks guys - I think a harshly worded letter to Greenway is in order, the rotation arrow definitely points against the grain. Which will get you nowhere other than looking like a muppet. They were designed by Greenway to run the way the arrow states, just because this goes against the design of some other similar treads does not mean that they are dangerous, wrong or inadequate - just different. Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted May 12, 2008 Share Posted May 12, 2008 And Greenway was part of Colway, so you're stuffed, as they are no more. Quote Link to comment Share on other sites More sharing options...
WHO? Posted May 13, 2008 Share Posted May 13, 2008 muck spreaders run the tyres backwards to hold the soil in the tread to try and stay on top of the ground, driven axles run the tyres point first to disapate the soft top soil to bite through to the harder more grippy soil underneath Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 13, 2008 Share Posted May 13, 2008 You've had tractors take off with you down hills? how is that related to tyres?plus what tractors do you have? Zetors? LOL! a 5ton case tractor with 2ton forage and a 7ton trailer on the back of that going down a hill in a grass field with allmost new tyres Quote Link to comment Share on other sites More sharing options...
WHO? Posted May 14, 2008 Share Posted May 14, 2008 a 5ton case tractor with 2ton forage and a 7ton trailer on the back of that going down a hill in a grass field with allmost new tyres and small shower of rain! then hope the gate is somewhere below you! not fun! i need to learn how to quote! doh! Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 14, 2008 Share Posted May 14, 2008 a 5ton case tractor with 2ton forage and a 7ton trailer on the back of that going down a hill in a grass fieldwith allmost new tyres and small shower of rain! then hope the gate is somewhere below you! not fun! i need to learn how to quote! doh! just click on quote at the bottom of the text(s) you want to quote then click reply Quote Link to comment Share on other sites More sharing options...
