LandyManLuke Posted May 19, 2008 Share Posted May 19, 2008 Can you get galvanised tub cappings for a 90? Is the best/most viable method to cut some 109" cappings down? Has anyone got any other ideas? Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 19, 2008 Share Posted May 19, 2008 I bought some from my local LR dealer about 6 months ago. bout 48 quid i think. Dave. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 19, 2008 Author Share Posted May 19, 2008 Galvanised? Do you have a part number? Microcat doesn't over any details on galvanised or not. Has anyone got a brand new set galvanised? I'd imagine warping/bending issues? Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 19, 2008 Share Posted May 19, 2008 Im assuming its this your after If so part number on my invoice is LASR1396 there was also the sealed rivets L78248 Hope this helps Dave. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 19, 2008 Author Share Posted May 19, 2008 They're the ones!! Do you have the part number for the other side? Cheers Luke Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 19, 2008 Share Posted May 19, 2008 no sorry i only replaced the one side Dave. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 19, 2008 Author Share Posted May 19, 2008 Ok, thanks. Google isn't showing anything for that part number, so it looks like i'll have to ring a main stealer! Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 19, 2008 Share Posted May 19, 2008 just looked on my LR parts cd its showing them up as MWC4686 RH and MWC4687 LH but they had changed numbers when i went to the dealers Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 19, 2008 Author Share Posted May 19, 2008 Is that just the side section then? Microcat has MXC5978 and MXC5979 as 'capping assembly' and shows a single piece including the short section on the rear. MWC4686 and MWC4687 are just listed as 'capping' No mention of either being galvanised, or an option for it either. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 19, 2008 Share Posted May 19, 2008 When I bought mine I was told they were galv, I think local steeler is the best option mine are very helpful Dave. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 19, 2008 Author Share Posted May 19, 2008 They certainly look it I've lived in sheffield for 4 years and never been to the main dealer - first time for everything i guess. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 19, 2008 Share Posted May 19, 2008 Is that just the side section then?Microcat has MXC5978 and MXC5979 as 'capping assembly' and shows a single piece including the short section on the rear. MWC4686 and MWC4687 are just listed as 'capping' No mention of either being galvanised, or an option for it either. i did mine on my 90 2 years ago i got mine from brookwells 01626833848. thay could get them but postage may cost to you Quote Link to comment Share on other sites More sharing options...
muddy Posted May 19, 2008 Share Posted May 19, 2008 got the rear tops and trapezium bits where the hinges go, so all else you would need is the bit for the rear lights if that helps. will. Quote Link to comment Share on other sites More sharing options...
Muther Trucker Posted May 21, 2008 Share Posted May 21, 2008 found one on fleabay earlier from a guy in leeds.... item 380028952869 Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted May 22, 2008 Share Posted May 22, 2008 found one on fleabay earlier from a guy in leeds.... item 380028952869 Thats the one I'm looking at as well!!!! What's your ebay id so we don't get into a bidding war? Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted May 22, 2008 Share Posted May 22, 2008 Just done some searching around and found via rimmer bros that the part numbers are ASR1396 and 1397 and found them here in galv Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 22, 2008 Share Posted May 22, 2008 My microcat lists the galvanised and non galv'd ones...... Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 22, 2008 Author Share Posted May 22, 2008 Cheers Jim, I have an older version of Microcat. it doesn't have them in it. maybe i should upgrade. Quote Link to comment Share on other sites More sharing options...
