NicTheOrange90 Posted May 26, 2008 Share Posted May 26, 2008 Do they come as separate part # They are not easy to get off with out the plastic thingy... is this available separately? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 26, 2008 Share Posted May 26, 2008 "lever, tool kit nut removal, production fit" part n. ANR5436 loads on eblag Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2008 Share Posted May 26, 2008 the other post of same subject have been deleted, reckon you must have had some finger or PC truoble. Quote Link to comment Share on other sites More sharing options...
Litch Posted May 28, 2008 Share Posted May 28, 2008 With my ZU alloys it is impossible to use the plastic tool to remove the cap so I use a pair of soft-jawed gas-pliers which do the job perfectly with no effort. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 28, 2008 Share Posted May 28, 2008 LR tool No 1? Pete Quote Link to comment Share on other sites More sharing options...
JSG Posted June 1, 2008 Share Posted June 1, 2008 I've always broken the plastic tool as well. The easiest way to remove the cover is with the socket you use to remove the wheelnuts - it will slip over and grip enough to 'wiggle' it off. Quote Link to comment Share on other sites More sharing options...
