jimmy_neutron Posted June 14, 2008 Share Posted June 14, 2008 Which standard LR alloys will fit straight on to a 1991 defender 90 van ? Is there anything else i will need or anything else i need to know ?? Quote Link to comment Share on other sites More sharing options...
wkw90 Posted June 14, 2008 Share Posted June 14, 2008 You will need the alloy wheel nuts as well . Paul Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2008 Share Posted June 14, 2008 provided your 90 has rear disc brakes any of the LR alloys for 90/110 will fit. if you choose Discovery or RR alloys check they will comfortably handle the 90's fully laden gross weight. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 14, 2008 Share Posted June 14, 2008 A 1991 will have drums on the back if standard, the discs only came in around 1993 some time, about the last 8000 or so 200Tdi vehicles Because of that I don't know if any of the standard rims will fit but I believe the aftermarket copies, e.g. the Firestyle, do fit drums without problems. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted June 14, 2008 Author Share Posted June 14, 2008 A 1991 will have drums on the back if standard, the discs only came in around 1993 some time, about the last 8000 or so 200Tdi vehiclesBecause of that I don't know if any of the standard rims will fit but I believe the aftermarket copies, e.g. the Firestyle, do fit drums without problems. Yeah its drums on the back.. Quote Link to comment Share on other sites More sharing options...
