Graham Thomson Posted June 19, 2008 Share Posted June 19, 2008 Anyone know? before i buy a magnetic aerial? - and it's 1989 vintage, not 1998!! Quote Link to comment Share on other sites More sharing options...
headhunter Posted June 19, 2008 Share Posted June 19, 2008 Is this a trick question? If not, the roof will be alloy, thus not magnetic. You could fix a steel plate to hold a magnetic aerial. Glue it to avoid galvanic corrosion. John Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted June 19, 2008 Share Posted June 19, 2008 Have a chat with "Tris Cocks" he had some vision of sticking signs to the side of my truck using some new fangled aliminium magnets. But seriously, you could bond a bit of steel plate to the roof using epoxy resin. Adrian Quote Link to comment Share on other sites More sharing options...
BigSi110 Posted June 19, 2008 Share Posted June 19, 2008 Why not drill a hole? It's what I did. Painful, but if it's for keeps then why not? Better reception and a more 'factory' job too. Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2008 Share Posted June 19, 2008 It'a a alloy roof Graham, so no good for magnetic antenna mounts, you could use a side mount attached to the panel above the left or right small windos each side of the rear door or a gutter mount. Quote Link to comment Share on other sites More sharing options...
Philip Tonkin Posted June 19, 2008 Share Posted June 19, 2008 It'a a alloy roof Graham Is that a ferrous or non-ferrous alloy? Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2008 Share Posted June 19, 2008 Is that a ferrous or non-ferrous alloy? as in LR's type birmabright alloy [a aluminium variant] Quote Link to comment Share on other sites More sharing options...
Philip Tonkin Posted June 19, 2008 Share Posted June 19, 2008 as in LR's type birmabright alloy [a aluminium variant] That 0.66% Magnesium makes all the difference! Let's just call it Aluminium. Quote Link to comment Share on other sites More sharing options...
western Posted June 20, 2008 Share Posted June 20, 2008 happy with that Quote Link to comment Share on other sites More sharing options...
