110 csw
Has anyone done a removal of the old tank and re-fit of a new tank on a 1986 110 csw. Mine is not leaking but it has taken a fair old battering. I was thinkng of doing this and any helpful suggestions would be very much appreciated, IE what should be taken of first and so on.
Many thanks
Mark
drain the tank
remove the sender unit
remove the rubber pipe to filler cap/neck
if fitted remove the 2 tow hitch chassis brace bars
disconnect all the fuel lines at the tank
support with a trolley jack or helper
undo the 4 bolts [2 front] & [2 rear]
lower the tank to the floor.
hth :D
