Rolling radius of 235/85 x 16!
ROGUE TROOPER
Generally speaking you knock off 5% from the aspect ratio for every inch increase in rim size, so
235/85R16
235/80R17
235/75R18
etc etc
should be roughly the same size within a few mm - near enough for gearing etc
see also tyre size calculator very useful :)
20in alloys on a Series a bit bling though innit? :ph34r:
Edited to say doh!! didn't spot Siggy's link.... :unsure:
Edited by BogBuster
Although as you're probably looking at a wider wheel as well as bigger, a profile such as 305/50 R 20, 305/55 R 18, 285/60 R 18 would be similar diameter.
graphical tyre calculator here although it doesn't go as far as 85%; I seem to recall it should be 31.2" although the other link says 31.73"..
