renault4 Posted July 13, 2008 Share Posted July 13, 2008 Is it advisable to replace the bolts and nuts when removing/fixing the prop shafts? I was just thinking, what a garage would do if they were changing the UJs. probably use the old ones. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 13, 2008 Share Posted July 13, 2008 I tend to use mine a coulpe of times, then replace, for what they cost...pence. although its only the nuts i usually change as the nylock bit gets worn out. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 13, 2008 Share Posted July 13, 2008 Why take the diff drive flange off each time ? If the bolts are in from the prop they are incorrectly fitted. In that case you cannot tighten the nuts easily or correctly. mike Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 13, 2008 Share Posted July 13, 2008 Nyloc nuts should only be used once so change the nuts each time you take the prop off. The bolts will be fine. Mo Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 13, 2008 Share Posted July 13, 2008 I agree with Diesel Jim, change the nuts as they don't cost much. Remember there are two lengths of bolts, the ones at the handbrake are longer, and difficult to change because you have to remove the driving member to get them out, so those are normally left alone anyway. And whatever you do, do not replace the UNF bolts and nuts with cheap Metric stuff. Quote Link to comment Share on other sites More sharing options...
wkw90 Posted July 13, 2008 Share Posted July 13, 2008 Nyloc nuts should only be used once so change the nuts each time you take the prop off. The bolts will be fine. Mo Agree , change the nuts whenever you take them off . Quote Link to comment Share on other sites More sharing options...
