Daan Posted January 6, 2006 Share Posted January 6, 2006 Hello, I saw this item on ebay: http://cgi.ebay.co.uk/LAND-ROVER-300TDi-MO...1QQcmdZViewItem Now I have a 300 TDI and the tendency to break the cambelt due to this problem is known by most of us. mine has not been updated with the set. Spending a tenner here would be affordable. I also like the idea of not fixing something unless its broken. Or should I not loose sleep over this problem anyway? it currently has about 25.000 miles from new. Daan Quote Link to comment Share on other sites More sharing options...
white90 Posted January 6, 2006 Share Posted January 6, 2006 (edited) Daan the kits to changing the timing case is still available if you need one. what is the chassis number? as you may only need kit 2 which has a new pullies/tensioner. STC4095K Kit - Option 1 is to be fitted to vehicles in the following VIN ranges: Discovery: MA 081991 to TA 200000 MA 500000 to VA 542370 TA 700000 to VA 711273 Defender: MA 939976 to VA 101256 Range Rover Classic: MA 647645 to MA 664120 STC4096K Kit - Option 2 is to be fitted to vehicles in the following VIN ranges: Discovery: VA 542371 to VA 558898 VA 711274 to WA 748935 Defender: VA 101257 to VA 129096 Range Rover Classic: Not applicable Additionally, ERR7143 Seal (Crankshaft Front) MUST also be fitted when fitting STC4096K Kit - Option 2 to vehicles in the following VIN ranges: Discovery: VA 548520 to VA 558898 VA 716697 to WA 748935 Defender: VA 107351 to VA 129096 Range Rover Classic: Not applicable not all 300's snap belts Tony Edited January 6, 2006 by white90 Quote Link to comment Share on other sites More sharing options...
Daan Posted January 6, 2006 Author Share Posted January 6, 2006 Tony, the VIN number is from a S3, so that is no good to check this. I do have, however, the engine number: S18L23978B Can you verify What i need by this? Thanks, Daan Quote Link to comment Share on other sites More sharing options...
white90 Posted January 6, 2006 Share Posted January 6, 2006 I'd pull the timing cover and see what has been done previously. the crank pulley is the main change with in th ekits the rest is rectifying the damage done by a looney tightening up the FIP mountings incorrectly distorting the timing case causing the premeture belt wear. Quote Link to comment Share on other sites More sharing options...
Daan Posted January 6, 2006 Author Share Posted January 6, 2006 I'd pull the timing cover and see what has been done previously. Well, apart from changing the oil, absolutely nothing has been done to this engine. This was the whole point of buying a brand new one. Having a black box under the bonnet which I can trust. I can see where you are coming from with this comment, but I am a bit reluctant to pull it all apart just to have a look. I do have the ability, following years of fxxxing about with old shxt boxes that were dying on their feet. Daan Quote Link to comment Share on other sites More sharing options...
white90 Posted January 6, 2006 Share Posted January 6, 2006 can you confirm the engine is brand new? if so then forget cambelt probs as the later variants were not affected by th eFIP/alignment prob Quote Link to comment Share on other sites More sharing options...
Daan Posted January 6, 2006 Author Share Posted January 6, 2006 It was brand new when I bought it, about 5 years ago, so that doesnt really tell anything I think. Would it be possible to verify which enginenumber is supposed to go with which VIN number? Daan Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 6, 2006 Share Posted January 6, 2006 Problem 300s were in the first couple of years of 300 production. A five year old engine will not require modification. Mo Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 7, 2006 Share Posted January 7, 2006 Replace the timing belt and buy a kit rather than the belt on it's own. This kit aligns the belt - note the crank sprocket with it's raised lip. The tensioners that were held by a bolt rather than a stud were supposedly in danger of working loose, so a stud and nyloc nut are also supplied to rectify this. It's important that you follow the instruction supplied with the kit. Les. Quote Link to comment Share on other sites More sharing options...
