trt1617 Posted July 18, 2008 Share Posted July 18, 2008 this question has probably been asked before but due to the fact of having to go look at a mot fail disco in a bit with a 300 tdi in it and due to my recent problems with my gearbox blowing up was wondering if anyone knows if a 300tdi engine and box will fit intoa 90 wihtout to much hassle and maybe the axels as well to gain disks on the back many thanks in advance Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted July 18, 2008 Share Posted July 18, 2008 I dont think the disco boxes fit the 90s. The Discovery has a short stick box and the 90 has a long stick. Some one will come along with a definitve anwser no dout. Dave. Quote Link to comment Share on other sites More sharing options...
western Posted July 18, 2008 Share Posted July 18, 2008 Forget the Disco box it won't fit as a straight drop in,but if you change the levers & internal parts it will. or it's possible to connect a 300Tdi to a LT77 how to here Disco transfer box will fit as will the rear disc axle. Quote Link to comment Share on other sites More sharing options...
jericho Posted July 18, 2008 Share Posted July 18, 2008 Engine - yes Gearbox - no axles - yes Of course you can make anything fit if you really want to. Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 as Jericho says ^^^ engine - you will need to grind off the old and fit new engine mounts thus keeping the G and T box in the same place as Std and being able to run std shafts. Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 18, 2008 Author Share Posted July 18, 2008 is the disco still a lt77 with a different bell housing, input shaft and lever box bit on the top coz the only bit of my box thats broken is reverse the input shaft is fine Quote Link to comment Share on other sites More sharing options...
western Posted July 18, 2008 Share Posted July 18, 2008 300Tdi has the R380 main gearbox, similar but no interchangable parts AFAIK. the 200Tdi Disco had LT77 boxes. Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 as Ralp says 300 disco had R380 the lt77 off a 200 disco has a different bell housing, different remote at the top, and longer input shaft i believe. Quote Link to comment Share on other sites More sharing options...
