eds Posted July 18, 2008 Share Posted July 18, 2008 Hello I would like to know if it is bad for my 200tdi to stall. I am not saying I stall it but occasionally I do get the gears wrong and very nearly stall it. Reverse hill starts are one, or thinking you are in a different gear, realising you are in the wrong gear but push on through almost stalling. As an engineer my guess that they would design the engine to be able to stall without there being any ill effect. Does anyone know, does it unduely stress the engine to stall or even worse nearly stall. Cheers Eds Quote Link to comment Share on other sites More sharing options...
nas90 Posted July 18, 2008 Share Posted July 18, 2008 HelloI would like to know if it is bad for my 200tdi to stall. I am not saying I stall it but occasionally I do get the gears wrong and very nearly stall it. Reverse hill starts are one, or thinking you are in a different gear, realising you are in the wrong gear but push on through almost stalling. As an engineer my guess that they would design the engine to be able to stall without there being any ill effect. Does anyone know, does it unduely stress the engine to stall or even worse nearly stall. Cheers Eds Not a problem for a 200TDi Defender. LR Experience instructors demonstrate stalling as a hill climb fail method. If you are failing the hill back-off the throttle stall the engine, hold on foot brake, change gear to reverse, foot off clutch, start engine on ignition key, vehicle under control to descend hill. If LR teach that way must be OK Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 Not a problem for a 200TDi Defender. LR Experience instructors demonstrate stalling as a hill climb fail method. If you are failing the hill back-off the throttle stall the engine, hold on foot brake, change gear to reverse, foot off clutch, start engine on ignition key, vehicle under control to descend hill. If LR teach that way must be OK they dont, they remind you to take your foot off the brake before you restart on the key Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 18, 2008 Share Posted July 18, 2008 They would be doing well to teach that in a 07 model !! Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 They would be doing well to teach that in a 07 model !! but they do, just use too high a gear for the hill, ie 3rd on a 2nd gear hill they still stall!!! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 18, 2008 Share Posted July 18, 2008 Tim If you took yours offroad you'd know! At least mine got dirty tyres yesterday Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 TimIf you took yours offroad you'd know! At least mine got dirty tyres yesterday Walfy a bit out of order, i would put money on the fact Tims has done more off road miles than yours. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 18, 2008 Share Posted July 18, 2008 Walfy,, Besides,, are we not getting O/T here Quote Link to comment Share on other sites More sharing options...
nas90 Posted July 18, 2008 Share Posted July 18, 2008 they dont, they remind you to take your foot off the brake before you restart on the key V8 auto's don't stall, don't usually fail a climb either Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 18, 2008 Share Posted July 18, 2008 V8 auto's don't stall, don't usually fail a climb either 2nd that Dave,, dran oil burners Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 18, 2008 Share Posted July 18, 2008 Walfy a bit out of order, i would put money on the fact Tims has done more off road miles than yours. I got the bite I was after but from someone different . Do you think I didn't realise that. Quote Link to comment Share on other sites More sharing options...
western Posted July 18, 2008 Share Posted July 18, 2008 Yep, stick to the topic Please Kim, stalling won't hurt the engine at all. Quote Link to comment Share on other sites More sharing options...
