JustTrev Posted July 21, 2008 Share Posted July 21, 2008 Hello Oh Great & Wise Ones! I rather urgently need a complete Carburettor for my 1955 2-litre 86-inch, including as much of the linkage as poss. No, I don't have one to exchange at Craddock's (& others) as someone else has the benefit of the original one! I'd be quite keen on a full set of new hydraulic brake cylinders as well - should there be any out there, or if someone knows where a source is. As time goes on, I might need a few other items....so all advice & info Very Gratefully Received! -JustTrev. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 21, 2008 Share Posted July 21, 2008 try a company called Pegasus Parts, they're local to me and I've bought alot of Series 1 parts that aren't available at say Craddocks but cheaper than Dunsfold prices! When i was running my 2ltr I found a 34ICH webber jetted for a 2.25 petrol made it go rather well, it'll bolt straight onto the manifold. oh and welcome froma relative newbie. Sorry for blatent plug. Quote Link to comment Share on other sites More sharing options...
HoggyN Posted July 24, 2008 Share Posted July 24, 2008 I rather urgently need a complete Carburettor for my 1955 2-litre 86-inch, including as much of the linkage as poss. No, I don't have one to exchange at Craddock's (& others) as someone else has the benefit of the original one!I'd be quite keen on a full set of new hydraulic brake cylinders as well - should there be any out there, or if someone knows where a source is. If you eventually find a source for new S1 carbs please post it one here - I'd be interested too. I have also heard that the Webber intended for the later Series models actually suits the S1 rather better. They used to be cheap too - until Webber went bust. Sodbury (RIP) used to be a good source for knackered S1 carbs. I'm sure I just fitted ordinary Series brake cylinders to my car - it stops ok! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 24, 2008 Share Posted July 24, 2008 I'd use a throttle body injection setup from a motorbike and fuel inject it... Quote Link to comment Share on other sites More sharing options...
steve b Posted July 24, 2008 Share Posted July 24, 2008 Hi JT, I have a selection of used S1 2 litre carbs, might be able to find some bit's of the throttle linkage too if you tell me which bits you are after. As mentioned above if you aren't doing a concours resto then the Weber off a SIII/IIA would work fine. Cheers Steveb Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 25, 2008 Share Posted July 25, 2008 i've got a spare webber i might let go of - removed from running 2.25 engine Quote Link to comment Share on other sites More sharing options...
