Guppy Posted July 28, 2008 Share Posted July 28, 2008 I was wondering if there's anyone out there who could give me the lowdown on PAS pipes? My hi-pressure Box-Pump hose has died at the crimped section near the banjo. I tried cutting out the knackered section and securing with jubilee clips but no success so a new one is in order. I'm assuming the new ones don't come 'pre bent' and that it's probably gonna be a b*tch of a job? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 28, 2008 Share Posted July 28, 2008 New ones should come ready to bolt in. Quote Link to comment Share on other sites More sharing options...
joe1 Posted July 28, 2008 Share Posted July 28, 2008 You could also try your local hydraulics guy and fit a longer hose - assuming there is still enough meat remaining on the pipe - might be a cheaper solution than a complete new unit...... Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2008 Share Posted July 28, 2008 I was wondering if there's anyone out there who could give me the lowdown on PAS pipes? My hi-pressure Box-Pump hose has died at the crimped section near the banjo. I tried cutting out the knackered section and securing with jubilee clips but no success so a new one is in order. I'm assuming the new ones don't come 'pre bent' and that it's probably gonna be a b*tch of a job? The replacement comes pre-formed ready to fit Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 28, 2008 Share Posted July 28, 2008 For the price of the replacement I would go with that as you'll pay similar money from a hydro place IMHO and may end up with something not quite right if you know what I mean.... Quote Link to comment Share on other sites More sharing options...
Guppy Posted July 28, 2008 Author Share Posted July 28, 2008 Cheers chaps. Put my mind at ease! It would appear that NTC5001 is the fella. Hopefully with the new pump (installed at the weekend) i'll be able to remove the pipe in situ rather than remove everything again! Quote Link to comment Share on other sites More sharing options...
pist0nbr0ke Posted July 29, 2008 Share Posted July 29, 2008 hi there guys, Sorry to hijack the thread a bit!! I am just doing a 200 upgrade in my 2.25 petrol 90 (on a C plate) Got the pump, got the box, got the resevoir. How is the best way to connect them up? which parts should i buy/make? Many thanks Neil Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2008 Share Posted July 29, 2008 depends on the end fittings on pump & steering box & what the part numbers ofboth are ? Quote Link to comment Share on other sites More sharing options...
pist0nbr0ke Posted July 29, 2008 Share Posted July 29, 2008 depends on the end fittings on pump & steering box & what the part numbers ofboth are ? No need to worry! my mate popped into the landrover orphanage in chippenham this afternoon and got a couple of pipes. Problem solved!! Cheers Neil Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2008 Share Posted July 29, 2008 nice mate you've got Quote Link to comment Share on other sites More sharing options...
pist0nbr0ke Posted July 30, 2008 Share Posted July 30, 2008 He is, He's got a 55 plate td5 that has had the full allisport treatment, seemed to keep up with the Ferrari's on the way to Le Mans!! Cheers Quote Link to comment Share on other sites More sharing options...
Guppy Posted July 30, 2008 Author Share Posted July 30, 2008 *Sigh* Another problem. My swanky new PAS (NTC5001) pipe has a different thread on the box end to the old pipe. I'm guessing one is imperial and one metric? Any ideas? I'm thinking of having a local boffin make up an adapter... Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2008 Share Posted July 30, 2008 can you stick up a photo of the pump connections on the pump body? it's the correct pipe going by age & engine. maybe the new pipe is identified wrong. Quote Link to comment Share on other sites More sharing options...
Guppy Posted August 1, 2008 Author Share Posted August 1, 2008 Right! Sorted! After taking a day off work and driving like a madman around north Gloucestershire and South Warwickshire, the old girl is finally reassembled! Turns out that my 'box is in fact a 3 bolt and thus classed as a 'conversion'. There are NO off-the-shelf pipes that will fit. So, armed with both new and old pipes, I was eventually directed through a chain of 8 engineers, eventually arriving at a chap called Richard in Temple Grafton near Stratford upon Avon who is a hydraulics specialist. To cut a long story short, he cut the end off my new pipe, and with the aid of a couple of industrial flanges, bolted the old pipe onto the new. Reassembled, pressurised and all good! Thanks for everyone's help! Quote Link to comment Share on other sites More sharing options...
