jason_landy99 Posted August 16, 2008 Share Posted August 16, 2008 what is the wheel Bolt Pattern on a land rover defender 90 Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 16, 2008 Share Posted August 16, 2008 what is the wheel Bolt Pattern on a land rover defender 90 5 on 6.5" Quote Link to comment Share on other sites More sharing options...
mrdoiron Posted June 24, 2015 Share Posted June 24, 2015 5 on 6.5" Is this the same bolt pattern for a 1988 LR90 ? (pre-Defender) ? I would like to find some wheels like the SVX model, and not sure if fit... thx Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2015 Share Posted June 24, 2015 All 90,110,127,130 & the Defender models all use the same stud pcd. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 24, 2015 Share Posted June 24, 2015 Is this the same bolt pattern for a 1988 LR90 ? (pre-Defender) ? I would like to find some wheels like the SVX model, and not sure if fit... thx Just watch the drive flange clearance. The early wide style won't let alloys sit on the face of the hub properly. Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2015 Share Posted June 24, 2015 Just watch the drive flange clearance. The early wide style won't let alloys sit on the face of the hub properly. Is this the same bolt pattern for a 1988 LR90 ? (pre-Defender) ? I would like to find some wheels like the SVX model, and not sure if fit... thx as a example of Ross's reply above this bit of info will show where a alloy wheel interferes when fitted to the original thick drive members http://www.web-rover.co.uk/nav.php?p=articles/alloys if your 90 already has rear disc brakes & the later thinner drive members or has a ex-RR or Discovery rear axle retro-fitted then there is no problem fitting your chosen alloy wheels. Quote Link to comment Share on other sites More sharing options...
mrdoiron Posted June 25, 2015 Share Posted June 25, 2015 as a example of Ross's reply above this bit of info will show where a alloy wheel interferes when fitted to the original thick drive members http://www.web-rover.co.uk/nav.php?p=articles/alloys if your 90 already has rear disc brakes & the later thinner drive members or has a ex-RR or Discovery rear axle retro-fitted then there is no problem fitting your chosen alloy wheels. Excellent - thanks to all for the input. mike Quote Link to comment Share on other sites More sharing options...
