tomcat404 Posted August 24, 2008 Share Posted August 24, 2008 Well as the title says I have a 300 tdi auto the last of the 300's before the ecu's . I have fitted the engine and box from what I was lead to believe was a late classic tdi auto. every thing is spot on apart from wiring the auto inhibit. For competition reasons the vehicle must only start in Park and neutral. There are 6 wires coming from the auto and tranfer box and so far I have managed to work the following out and all working so far: Dark Green = live feed into the switch Light green with brown trace reverse feed out Black purple feed to the tranfer box, difflock light, black return out. Black with light brown trace coming out which has a orange with black trace joined on at the end, Seperate yellow wire too. Any help would be really appreciated with this !! cheers nathan Quote Link to comment Share on other sites More sharing options...
Mark90 Posted August 24, 2008 Share Posted August 24, 2008 I can't remember the colur codes but when I done an auto install I simply identified the wires using a multi meter. There should be a pair that are closed when in neutral or park and open in all other gears. Wire these between ignition switch and starter relay. Quote Link to comment Share on other sites More sharing options...
tomcat404 Posted August 24, 2008 Author Share Posted August 24, 2008 I can't remember the colur codes but when I done an auto install I simply identified the wires using a multi meter. There should be a pair that are closed when in neutral or park and open in all other gears. Wire these between ignition switch and starter relay. Hi Mark, The two wires i have left were the yellow and the Black with the brown trace which is coupled to the orange and black a little further down on the bit of a loom. It was this wire that is earthed in park and neutral, the yellow ? till tomorrow i suppose thanks nathan Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 24, 2008 Share Posted August 24, 2008 Some info here Quote Link to comment Share on other sites More sharing options...
Boothy Posted August 24, 2008 Share Posted August 24, 2008 Hello hello hello And what competition are you entering Natham, best haircut or shiniest paintwork???? Boothy Quote Link to comment Share on other sites More sharing options...
tomcat404 Posted August 24, 2008 Author Share Posted August 24, 2008 Hello hello helloAnd what competition are you entering Natham, best haircut or shiniest paintwork???? Boothy Hello fella, You know me never standing still, don't know if your aware but I have another addition to the family ! little boy nearly a month ago ! given me time to swap the engines over an mess with the springs. The auto box inhibit has been pi^&ing me off all day I though I had it today ! Any hew whats this about v8 drinking more water than petrol ???? nice piccy !! any thoughts on the wiring twiggy !! nath ( shirley) Quote Link to comment Share on other sites More sharing options...
will_warne Posted August 24, 2008 Share Posted August 24, 2008 Nathan, can I recommend you wire the inhibitor so it only starts if you are in park OR if you have your foot on the brake - it just makes it faster to restart during a competition and will still pass scruteneering B) Quote Link to comment Share on other sites More sharing options...
taz90 Posted August 25, 2008 Share Posted August 25, 2008 on my 1992 zf with bw t/case the wires are black/orange- inhibit switch works to earth when in park neutral green - feed green /brown- rev light yellow- speed transducer black/purp t/case temp works to earth hope this helps tazza Quote Link to comment Share on other sites More sharing options...
tomcat404 Posted August 25, 2008 Author Share Posted August 25, 2008 on my 1992 zf with bw t/case the wires areblack/orange- inhibit switch works to earth when in park neutral green - feed green /brown- rev light yellow- speed transducer black/purp t/case temp works to earth hope this helps tazza Hi Tazza, thanks for the info i'll try this week ! cheers nath Quote Link to comment Share on other sites More sharing options...
