disco_al Posted September 24, 2008 Author Share Posted September 24, 2008 not had chance to get underneath her again lately (bailing, shifting 200tdi's around and that annoyance called work ) hoping to at the weekend all being well (got a defender to fit a 200 tdi into, so looking doubtful) Quote Link to comment Share on other sites More sharing options...
disco_al Posted November 21, 2008 Author Share Posted November 21, 2008 well it's been a while since i last had a look at this problem, but last weekend i rebuilt the N/S swivels with new swivel bearings (TRE's already done from before), preload set,, wheel bearing set - and it still shakes about over potholes. not much left to try now, so going to get both wheels off the ground tomorrow (if it's not too cold outside) and give everything a damn good inspection. Quote Link to comment Share on other sites More sharing options...
discojmz Posted November 21, 2008 Share Posted November 21, 2008 but youve still not tried a different steering damper? Quote Link to comment Share on other sites More sharing options...
disco_al Posted November 21, 2008 Author Share Posted November 21, 2008 um....not yet, no but it does feel more like suspension related than steering to me, feels like the wheel is bouncing up and down. i have a later type drop arm and drag link, so may swap that over as i don't like the earlier "ball joint in drop arm" design. Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted November 21, 2008 Share Posted November 21, 2008 I solved my problems. I should have posted an update sooner - sorry. I replaced all 4 TRE's and changed the front shocks for Britpart Cellular's. I know a lot will think this is heresy but I'll never buy pro-comp again. 14 months old and all the damping properties of a blancmange. My problem was solved straight away and the truck has never handled so good. Look again at your shockers al.... Quote Link to comment Share on other sites More sharing options...
disco_al Posted November 21, 2008 Author Share Posted November 21, 2008 hmmm, the ones i fitted are gabriel gas units (got them through work) that are usually pretty good. i had a quick check around at lunchtime, and have found a bit of play in the n/s wheel, so i will recheck and tighten the bearing back up a bit. the o/s t/r end wouldn't budge when i had a go at it last, so will probably whip it off completely to have a go at it Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted November 21, 2008 Share Posted November 21, 2008 Be careful with TRE's. One side has a left hand thread. I sheared one off using a scaffold pole on stilsons trying to remove it! If you can, heat the steering bar up a bit before you try to turn them, this seemed to help on mine. Stu. Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted November 23, 2008 Share Posted November 23, 2008 IMHO steering dampers only mask issues not solve them, there should be no real shakes etc without a damper fitted at all. I would (and have myself) change all your radius and panhard rod bushes for piece of mind (proper ones not poly but that is another debate) as I had naff radius arm bushes that was causing my front axle to jump about. I need to do the swivel preload on mine as I get the same shakes even with a brand new box, bushes, springs and dampers and know my swivels are a bit loose. Steering/suspension shakes are great fun to find! Quote Link to comment Share on other sites More sharing options...
