benbenukuk Posted September 13, 2008 Share Posted September 13, 2008 I want to change the fuel filter in my 1989 rrc but in the Haynes manual it tells me to depressurise the fuel system will I have to do this or can I just swap it over? cheers. Ben Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted September 13, 2008 Share Posted September 13, 2008 On my 90 RRC 3.9, I pull up the button on the crash sensor (under the passenger seat) while the engine is running and wait for it to stall Even so when I split the pipe there was some spillage, but no spurt. I would think that an 89 is similar. Roger Edited: Lifting the crash sensor button effectively switches off the fuel pump. Quote Link to comment Share on other sites More sharing options...
DC_ Posted September 13, 2008 Share Posted September 13, 2008 Hi Ben matey, I done the filter on my 92 RRC, the manual also told me to depressurise the system, all i done was start the engine, let it idle and then pull the fuel pump fuse out, Then changed the filter with no probs. Hope that helps DC Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 13, 2008 Share Posted September 13, 2008 The fuel filter is in the pressure line, so yes you'll need to depressurise it as described above. Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted September 14, 2008 Share Posted September 14, 2008 after it stalls, if you crank it over and try to restart it, it should remove the last bit of pressure. Quote Link to comment Share on other sites More sharing options...
benbenukuk Posted September 14, 2008 Author Share Posted September 14, 2008 Thanks for your replys I will be changing my fuel filter soon, cheers. Ben Quote Link to comment Share on other sites More sharing options...
