popotla Posted September 28, 2008 Share Posted September 28, 2008 I want to buy a bottle jack for my LR Defender. These are pretty thin on the ground where I live, especially since I won’t buy one made in China. “Mega” brand is available (Melchor Gabilondo, Vigo, Spain) and I’d be happy with that. There is a 3-ton model (costs equiv. GBP 18) and a 15-ton (GBP 36). Am I right in thinking that the 15-ton one, with its spare capacity and better able to lift a fully-loaded vehicle, is the one to go for? But how can I be sure it’s compact (low) enough to fit under the axle when I have a flat tyre, and extends high enough (gives enough lift)? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted September 28, 2008 Share Posted September 28, 2008 I would expect maximum and minimum distances to be quoted, along with the pressure/force etc. Quite a few bottle jacks have a screw-out first section, so you only need to use the extension of the ram as you started lifting. 15 ton does seem a little bit excessive. Quote Link to comment Share on other sites More sharing options...
popotla Posted September 29, 2008 Author Share Posted September 29, 2008 Thanks for this advice. What capacity would you recommend, then? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 29, 2008 Share Posted September 29, 2008 The standard, excellent, LR bottle jack is 2 or 3 tonne capacity. I would say 3 tonne is more than enough. Don't forget that the jack will have a factor of safety of 5 or more.... The most important part for a jack for a LR is having enough reach. I would use that as your main criterion. You can get LR jacks cheaply in the UK or ebay is your friend Quote Link to comment Share on other sites More sharing options...
Escape Posted October 1, 2008 Share Posted October 1, 2008 The standard, excellent, LR bottle jack is 2 or 3 tonne capacity.I would say 3 tonne is more than enough. Don't forget that the jack will have a factor of safety of 5 or more.... The most important part for a jack for a LR is having enough reach. I would use that as your main criterion. You can get LR jacks cheaply in the UK or ebay is your friend I agree, 2 ton capacity is enough, but most small bottle jack do not have sufficent reach to suit a LR. That's why the standard LR jack, as supplied with the Range Rover for example, has a double extending cilinder, giving you plenty of reach even with bigger tyres (I use one for my 37"). Quote Link to comment Share on other sites More sharing options...
jacks906 Posted October 1, 2008 Share Posted October 1, 2008 the one that i have think out of a discovery has a u shaped top this sits under the axle nicely and safe better than a flat tops you usually get on a bottle jack dave Quote Link to comment Share on other sites More sharing options...
