mudmad Posted October 3, 2008 Share Posted October 3, 2008 Hi all, does any one know if a disco 3 double cardan prop will fit on a defender ?, a friend works at a local landy parts shop and he tells me that it should fit and he can do these plus the flange for less than the cost of a tank of diesel ! !. any help would be appreciated Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 3, 2008 Share Posted October 3, 2008 I think you mean Disco 2, although no-one has tried Disco 3 bits yet that I know of. Quote Link to comment Share on other sites More sharing options...
mudmad Posted October 3, 2008 Author Share Posted October 3, 2008 It could be to be honest cant remember which one he said it was off but does a disco 2 have the double cardan prop, if it does do you know if they fit a defender ? Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 3, 2008 Share Posted October 3, 2008 It could be to be honest cant remember which one he said it was off but does a disco 2 have the double cardan prop, if it does do you know if they fit a defender ? Yes the do with the correct flange. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 3, 2008 Share Posted October 3, 2008 You can fit a 300Tdi Defender front prop onto a Td5 D2 so yes probably ... however the LR shaft is about £450 so I hope your diesel tank is a fair size!! Quote Link to comment Share on other sites More sharing options...
mudmad Posted October 3, 2008 Author Share Posted October 3, 2008 You can fit a 300Tdi Defender front prop onto a Td5 D2 so yes probably ... however the LR shaft is about £450 so I hope your diesel tank is a fair size!! Shaft ? , i was told i could just replace the flange . i was quoted £100 for the prop and £20 for the flange, Quote Link to comment Share on other sites More sharing options...
JST Posted October 3, 2008 Share Posted October 3, 2008 at a £120 you may as well go to prop shaft clinic or D4x4 and get a decent one, D2 2DC props aren't greasable IIRC Quote Link to comment Share on other sites More sharing options...
