draper40 Posted November 1, 2008 Share Posted November 1, 2008 Hey, 1) I have been told to use one shot grease in my warn gearbox - it This okay? If so how much will i need- just the one or more? 2) I have a NATO hitch on the back and would like one of those rings to go in it so I can attach towbar/shackles etc. Is the one of the end of here suitable as he will sell them separtaley. Thanks Pete Quote Link to comment Share on other sites More sharing options...
gsr341 Posted November 1, 2008 Share Posted November 1, 2008 what ''warn gear box'' are you wanting to fill with grease (guessing its a low line range model ?) as long as that ring has a decent rating on it should be fine Quote Link to comment Share on other sites More sharing options...
SteveG Posted November 1, 2008 Share Posted November 1, 2008 I've been using one shot grease in EP9's for a couple of years now and it works well. You'll use about half a tube per service. Cheers Steve Quote Link to comment Share on other sites More sharing options...
draper40 Posted November 1, 2008 Author Share Posted November 1, 2008 what ''warn gear box'' are you wanting to fill with grease (guessing its a low line range model ?) xd9000i if it matters. So the ring will fit in a NATO hitch? Pete Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted November 1, 2008 Share Posted November 1, 2008 One shot is okay, LM2 is cool but Red Line is best (and oh so expensive) Speak to Anton ay OEC about master rings - he sells the right sort at the right loading Quote Link to comment Share on other sites More sharing options...
draper40 Posted November 1, 2008 Author Share Posted November 1, 2008 l but Red Line is best (and oh so expensive) This stuff? Thanks Pete Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted November 1, 2008 Share Posted November 1, 2008 Yerrs but I buy it in bigger pots! Quote Link to comment Share on other sites More sharing options...
draper40 Posted November 3, 2008 Author Share Posted November 3, 2008 Can I just use normal multi-purppose grease? Thanks Pete Quote Link to comment Share on other sites More sharing options...
draper40 Posted November 11, 2008 Author Share Posted November 11, 2008 I've decided redline looks to expensive and so I'm looking for LM2 grease. Is this Castrol LM Grease the same or is it something different. Can the above be used? Thanks pete Quote Link to comment Share on other sites More sharing options...
pugwash Posted November 11, 2008 Share Posted November 11, 2008 LM grease is a high temperature stable grease often used in wheel bearings and such like it is different from Moly grease (which is afaik what one shot grease is) in that it doesn't liquify under pressure or temperature as Moly grease seems to. Quote Link to comment Share on other sites More sharing options...
draper40 Posted November 12, 2008 Author Share Posted November 12, 2008 So LM is suitable for a winch gearbox? Quote Link to comment Share on other sites More sharing options...
