landmannnn Posted November 15, 2008 Share Posted November 15, 2008 I was in netto/aldi/lidl, can't remember which, they do a 2hp 24lt 8cufm compressor for £50. If you bought 2 and tee'd them to a single output, would that give you the equivalent of a 4hp, 16 cfm, 50 litre compressor for £100? Obviously the psi wouldn't change. In theory it seems a good way of boosting cufm to run more hungry tools for not a lot of money. Have I missed something? Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted November 15, 2008 Share Posted November 15, 2008 it should, Quote Link to comment Share on other sites More sharing options...
pinny Posted November 15, 2008 Share Posted November 15, 2008 youll need a non return valve fitted to the outlet of each or one will mess the other up but we sometimes use 2 250cfm compressors toghether into one receiver for shotblasting so no probs as long as a non return is fited on each outlet ,chris. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted November 15, 2008 Share Posted November 15, 2008 In what way would they get confused if no non return was fitted? I was thinking about doing this. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted November 16, 2008 Share Posted November 16, 2008 You'll need a non-return valve if you only run one at a time - otherwise you'll pump up the tank of the non-running one (which you may want to do) Alternatively shut its output manually. As both will be constructed to work against the back pressure contained in the tank I can't see that any other modification is needed. Quote Link to comment Share on other sites More sharing options...
