Mack Posted December 6, 2008 Share Posted December 6, 2008 The vacuum brake pump just broke and replaced by LR012183. Is this the new/old model? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 6, 2008 Share Posted December 6, 2008 Must be the new one. my version of MC shows the latest pump as LR006872 (although i'm working one a newer one than septemer 08 which i have currently) Quote Link to comment Share on other sites More sharing options...
cipx2 Posted December 6, 2008 Share Posted December 6, 2008 According to the latest TSB on the matter LR012183 is the new version. See here: http://forums.lr4x4.com/index.php?showtopic=33238 Quote Link to comment Share on other sites More sharing options...
cipx2 Posted December 10, 2008 Share Posted December 10, 2008 I've updated my EPC and there it is: Quote Link to comment Share on other sites More sharing options...
Eduardo Posted December 10, 2008 Share Posted December 10, 2008 Mack, Finally you got the new one Looks like a "normal" problem for the Pumas (mine failed in May, but was replaced by the old one ) Regards! Eduardo Quote Link to comment Share on other sites More sharing options...
JST Posted December 10, 2008 Share Posted December 10, 2008 is this the 'dirt ingress' problem/ misalignment problem? Quote Link to comment Share on other sites More sharing options...
MJIbex Posted December 10, 2008 Share Posted December 10, 2008 is this the 'dirt ingress' problem/ misalignment problem? I'm interested in this thread because its what I was considering replacing my GM pump with. I had a look today the LR retail price is in the high £300's, eek!!! But found this as a bit more reasonable. e-bay link However if this needs an oil supply this brings around another problem! Mark. Quote Link to comment Share on other sites More sharing options...
Mack Posted December 11, 2008 Author Share Posted December 11, 2008 I'm interested in this thread because its what I was considering replacing my GM pump with. I had a look today the LR retail price is in the high £300's, eek!!!But found this as a bit more reasonable. e-bay link However if this needs an oil supply this brings around another problem! Mark. In deed it uses the engine oil. Quote Link to comment Share on other sites More sharing options...
disco_al Posted December 11, 2008 Share Posted December 11, 2008 this was a common problem on the transit's/mondeo's with the same(ish) engines. the O ring on the back used to leak. IIRC Ford released an updated pump for them. Quote Link to comment Share on other sites More sharing options...
gemsbok Posted March 28, 2009 Share Posted March 28, 2009 My second vacuum pump, which was the new version, has just sprayed the engine compartment with oil. So when are they going to come up with something that does not do this every 20,000KM? Anyone know how many Pumas this is affecting? Am I just really unlucky? Cheers Ruaraidh Quote Link to comment Share on other sites More sharing options...
