Guess what this is?
Yes, it is an old drop arm ball pin used to get the inner thingy out. I don't understand what you are saying about a 300tdi as this tool is from and is to be used on 300tdi Defenders. Maybe the Disco is different.. And changing the drop arm! I don't know anyone who has managed to get one off :o
Anyway, many folks can't get the bush out of the drop arm so leave it behind. This is a mistake as the bush is softer than the pin and wears faster.
Of course, getting all the bits and springs and plates back into the drop arm is a story to itself :blink:
Small bottle jack with a socket on top to push the bottom plate up against the spring while you slip the circlip in makes the job much easier.
Jim
The later Discovery have a different drop arm and drag link.The drag link has track rod ends at both ends.
Sorry but I have no idea which year they started to fit that arrangement.
I eat rat poisonThey increased my dosage again today
mike
I can cause trouble in an empty house !!
Yes, true, that is the only way to do it... and then boing!!!! and the whole lot goes in all directions :o
It is good training in swear words of various sorts. Oh well, you have to have a sense of humour if you do this sort of job in a Land Rover :rolleyes:
:lol: yep, its a Land Rover thing.
I have never had any trouble getting the drop arm off, just undo the nut, fit a puller and it comes off every time.
I have done all of mine this way, without any problems at all.
No doubt next time I do this job, I will get the drop arm from hell, just to prove me wrong.
