jules Posted February 3, 2006 Share Posted February 3, 2006 I friend has asked me what to look for on a high mile freelander 140000k for £5k All I could think was anything that would go wrong would have, long ago. any thoughts guys Quote Link to comment Share on other sites More sharing options...
white90 Posted February 3, 2006 Share Posted February 3, 2006 I friend has asked me what to look for on a high mile freelander 140000k for £5k All I could think was anything that would go wrong would have, long ago. any thoughts guys IRD/prop carrier bearings/suspension bushes we are well pleased with our TD4 nice to drive good on fuel overall a very good vehicle IMHO Quote Link to comment Share on other sites More sharing options...
jules Posted February 4, 2006 Author Share Posted February 4, 2006 Good piont the rear diff would be due some new bushes as well Quote Link to comment Share on other sites More sharing options...
Jon W Posted February 4, 2006 Share Posted February 4, 2006 This is taken from the other post a while back when Chris Watts was thinking of buying a freelander: "Just a quick note on high miler TD4s - afaik you can't rebore them. Dad had to have a new engine fitted to his X-plate TD4 at around 160k (regularly maintained, mostly motoway miles). Mark" Haven't got a clue if this is correct or what would be worth further investigation if it is the case as the engine would only have up to 40k left in it, but saying that it could go on a lot longer and be fine HTH Jon Quote Link to comment Share on other sites More sharing options...
jules Posted February 15, 2006 Author Share Posted February 15, 2006 This is taken from the other post a while back when Chris Watts was thinking of buying a freelander:"Just a quick note on high miler TD4s - afaik you can't rebore them. Dad had to have a new engine fitted to his X-plate TD4 at around 160k (regularly maintained, mostly motoway miles). Mark" Haven't got a clue if this is correct or what would be worth further investigation if it is the case as the engine would only have up to 40k left in it, but saying that it could go on a lot longer and be fine HTH Jon I have never come across that before. Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 16, 2006 Share Posted February 16, 2006 Problem could be that rather than the block not being boreable, it may be that no oversized pistons are available. HTH Jon Quote Link to comment Share on other sites More sharing options...
Jon White Posted February 16, 2006 Share Posted February 16, 2006 Hmmm just checked - LFL104980L is listed as a +0.25 piston for a TD4, so my reckoning on that front is that it must be re-buildable! Bottom end shells are also available in -0.25 and -0.50 so again - its rebuildable! Jon Quote Link to comment Share on other sites More sharing options...
