orangemach5 Posted December 14, 2008 Share Posted December 14, 2008 Hi all, While out playing yesterday, whilst winching my mates 90 out of a bog i realised i have a strange problem with the brake on my 8274. When spooling out (power out or freespool) the outer ratchet ring of the brake seems to wobble about and as a result eash revolution you get a horrible click. It is only the second recovery i have made and the only mods i have is rufftraks 11mm plasma. What could be causing the brake ratchet ring to wobble (the centre of the brake seems to run true!) and not run true especially with this little use???? The brake still works well and when winching in it all seems normal! Help!!!! Quote Link to comment Share on other sites More sharing options...
white90 Posted December 15, 2008 Share Posted December 15, 2008 http://www.devon4x4.com/forum/vehicle-prep...50530/#msg50530 Bit here about the Brake Quote Link to comment Share on other sites More sharing options...
ciderman Posted December 15, 2008 Share Posted December 15, 2008 Yep it does sound normal to me , But an upgrade to Gigglepin oversized brakes smeared with a good coating of grease helps the problem . Quote Link to comment Share on other sites More sharing options...
TOR4x4 Posted December 15, 2008 Share Posted December 15, 2008 Yep it does sound normal to me , But an upgrade to Gigglepin oversized brakes smeared with a good coating of grease helps the problem . you on commission? Quote Link to comment Share on other sites More sharing options...
tblandy Posted December 15, 2008 Share Posted December 15, 2008 Carefull on jumping in and dismantling the brake though, there a pain to get back together! Mine still in bits, carnt get the 21 ball bearing back in where they should sit LOL Quote Link to comment Share on other sites More sharing options...
orangemach5 Posted December 15, 2008 Author Share Posted December 15, 2008 LOL, Ive heard they can be a royal pain! Looks like a phone call to Gigglepin for a mainshaft kit, their brake lining and depending on my bank managers mood an XP motor Quote Link to comment Share on other sites More sharing options...
ciderman Posted December 16, 2008 Share Posted December 16, 2008 you on commission? LOL,Ive heard they can be a royal pain! Looks like a phone call to Gigglepin for a mainshaft kit, their brake lining and depending on my bank managers mood an XP motor Jim just remember where he heard it first . Quote Link to comment Share on other sites More sharing options...
jacks906 Posted December 18, 2008 Share Posted December 18, 2008 mine was all ok to pop back together went like this get back brake plate ring of grease were balls needs to go ( so wrong on every level ) an stick them too it pop brake disc on then toothed disc ( correct way second time) then spring in middle then that thick metal plate bit other brake disc the outta brake plate circlip an done just totally rebuilt mine with everything from gigglepin ( if you work there an some random phoned up about bushes today that was me ) super mega helpful dave Quote Link to comment Share on other sites More sharing options...
bush doctor Posted December 19, 2008 Share Posted December 19, 2008 Carefull on jumping in and dismantling the brake though, there a pain to get back together! Mine still in bits, carnt get the 21 ball bearing back in where they should sit LOL Get yourself 2 pairs of medium sized long nose mole grips. Makes life alot easier. Quote Link to comment Share on other sites More sharing options...
tblandy Posted December 19, 2008 Share Posted December 19, 2008 To hold...... I greaded the outer brake casing closes to the winch on,greaded the brake shoes on, then add the ball bearings in grease, then added the outer brake casing and tightened the bolt. How can i test if my brakes working with no motor on????? Quote Link to comment Share on other sites More sharing options...
jacks906 Posted December 19, 2008 Share Posted December 19, 2008 as a small non weight holding way is to hold outer an inner brake plates and move one forward an one backwards they should move closer together then spring back to were they started also mats changed his pads for gigglepin ones first two time the brake didnt want to hold but has held him ever since so just be aware, not sure if this is common tho? was on an older type with the holes in centre toothed ring and fins on the outta dave Quote Link to comment Share on other sites More sharing options...
