Shaneshaneukuk Posted January 13, 2009 Share Posted January 13, 2009 Hi, will my L reg 1994 200tdi defender 90 have 10 spline or 24 spline? cheers. Shane Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 13, 2009 Share Posted January 13, 2009 You are right on the change over I am affraid. Despite what others may tell you regarding the appearance of the end of the shaft at the wheel, the only way to be certain is to undo the five bolts holding the shaft in and pull it out of the axle and count the splines. Be sure to park the vehicle so the side you want to work on is slightly hight to prevent the diff oil draining out. With steel wheels you don't even have to take the wheel off. Should be done and dusted in 20 minutes. Quote Link to comment Share on other sites More sharing options...
western Posted January 13, 2009 Share Posted January 13, 2009 make sure you chock all the wheels both ways cos if you pull a rear halfshaft it will roll away if not on level ground wonder how I found out, cost me a new fence for the nieghbours garden Quote Link to comment Share on other sites More sharing options...
Briarston Posted January 13, 2009 Share Posted January 13, 2009 make sure you chock all the wheels both ways cos if you pull a rear halfshaft it will roll away if not on level groundwonder how I found out, cost me a new fence for the nieghbours garden The "L" reg. Disco I have just robbed had 24 spline shafts, front and rear. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted January 14, 2009 Share Posted January 14, 2009 make sure you chock all the wheels both ways cos if you pull a rear halfshaft it will roll away if not on level groundwonder how I found out, cost me a new fence for the nieghbours garden Or put the centre diff lock in and handbrake on. Quote Link to comment Share on other sites More sharing options...
