stuntman Posted January 21, 2009 Share Posted January 21, 2009 Hello one and all. I'm just after a little advice really. I have 2 engines to decide between, both 2.25 litres, Can some one just help me with which would be most useable everyday, ie mpg, driveability etc. Also if it is the petrol is it work fitting a webber carb kit to it? Also, is it worth fitting a 2.5 petrol defender engine with twin carb webber? or the 2.5d or 2.5td, I am considering a 200 tdi but cost may be prohibitive as this is a cheap project. Thanks in advance Andi Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 21, 2009 Share Posted January 21, 2009 2.25 diesel is a bad idea unless you like doing ~50mph max. 2.25 petrol, if it's a good one, would be fine. 2.5 petrol would gain you a bit of power & torque but MPG is likely to be marginal 2.5 diesel is a strong lump but not going to win drag races 2.5 TD are not universally loved, they're a bit fragile if not cared for. The 200TDi would probably give good power & the best MPG for a daily driver A V8 would give best power and similar MPG to the petrol lumps if it's EFI, and you'd get there much quicker with a silly grin Fancy carbs only ever seem to bring new problems, if you want to be different you could MicroSquirt a 4-pot petrol lump as I'm sure there's a lot of potential to be unlocked. Quote Link to comment Share on other sites More sharing options...
stuntman Posted January 22, 2009 Author Share Posted January 22, 2009 Thanks fridge, I think I'm set on a 200di installation as I have a spare one in the garage that needs a rebuild Quote Link to comment Share on other sites More sharing options...
Rich_P Posted January 25, 2009 Share Posted January 25, 2009 Why a 200Di? Why remove the turbocharger? You're turning the engine into something not much more than a 2.5 NA.... Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted January 26, 2009 Share Posted January 26, 2009 Why a 200Di? Why remove the turbocharger? You're turning the engine into something not much more than a 2.5 NA.... the usual wisdom was to avoid stressing the rest of the drive train Quote Link to comment Share on other sites More sharing options...
tacr2man Posted January 26, 2009 Share Posted January 26, 2009 Thats what the acceralor pedal is for , the turbo will give you what power you decide, it can also result in better fuel economy. Top is direct , and the transmission will handle quite a lot of power if driven in a sympathetic manner . 200tdi is way to go . JMHO Quote Link to comment Share on other sites More sharing options...
stuntman Posted January 26, 2009 Author Share Posted January 26, 2009 I have to amit I still don't know what I'm doing with it Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 26, 2009 Share Posted January 26, 2009 Taking the turbo off a 200TDi seems like the daftest idea ever - why not just sell it to someone for good money and find a cheap 2.5D that someone's throwing away? The Series drivetrain is not very strong but they handle V8's OK driven with a bit of care so I can't see how the awesome tarmac-shredding power of a 200TDi is going to bother it Quote Link to comment Share on other sites More sharing options...
T1G UP Posted January 26, 2009 Share Posted January 26, 2009 Taking the turbo off a 200TDi seems like the daftest idea ever - why not just sell it to someone for good money and find a cheap 2.5D that someone's throwing away? The Series drivetrain is not very strong but they handle V8's OK driven with a bit of care so I can't see how the awesome tarmac-shredding power of a 200TDi is going to bother it What about the 200 tdi and gearbox! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 26, 2009 Share Posted January 26, 2009 What about the 200 tdi and gearbox! If you mean use the LT77 off the back of the 200TDi then you're in to either an expensive adapter plate to mate it to the Series box, or fitting an LT230 which in an 88" is a squeeze, and the gearing will be out by ~30%. If it's from a Disco or RR then the bellhousing is long and the gearstick will be in the centre seatbox. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted January 26, 2009 Share Posted January 26, 2009 200Tdi and be kind to it. Di is a waste of time, no better than a good NA from experience. Quote Link to comment Share on other sites More sharing options...
