fats_40 Posted January 22, 2009 Share Posted January 22, 2009 need to change battery on p38 n reg,is there anythink i need to know or is it just a swap over,regards me Quote Link to comment Share on other sites More sharing options...
paintman Posted January 23, 2009 Share Posted January 23, 2009 have a look at http://www.rangerovers.net/rrupgrades/battery.html Quote Link to comment Share on other sites More sharing options...
q-rover Posted January 23, 2009 Share Posted January 23, 2009 Simple procedure. -Loosen - on battery pole -turn on ignition, but don't crank engine, turn off -quickly disconnect - terminal -disconnect + terminal -remove and replace battery -leaving drivers door open, and keys no where near or in the vehicle, reconnect + -reconnect - -recallibrate windows and sunroof by fully opening and holding, and fully closing and holding the switches. Should be good to go. Quote Link to comment Share on other sites More sharing options...
Escape Posted January 23, 2009 Share Posted January 23, 2009 Nothing complicated really, just make sure the keys are in your pocket and not in the car/ignition. Afterwards reset the windows and sunroof, possibly resync the remote and that's it. Quote Link to comment Share on other sites More sharing options...
paintman Posted January 23, 2009 Share Posted January 23, 2009 Read the link I put. If you do it the 'unofficial' way using jump leads as it shows then you won't need to reset anything. Quote Link to comment Share on other sites More sharing options...
